CFX, StarCD or Flow-3D
View Poll Results: Which CFD package is the best in terms of overall ability,ease of use, tech support?
CFX 7 63.64%
StarCD 4 36.36%
Flow-3D 0 0%
Voters: 11. You may not vote on this poll
Old   September 22, 2009, 15:23
Default CFX, StarCD or Flow-3D
Gavin White
CFDUS is on a distinguished road
Dear forum members,
Which of the threee software packages is the best in terms of proce, software ability, easy of use and the quality of tech support?
I am evaluating them for my company. The main application would be simulating mixing in commercial scale reactors, fluid behaviors in liquid filling machine and fluid behavior in syringe/needle system.
Thanks a lot.
CFDUS is offline   Reply With Quote
Old   October 8, 2009, 12:47
Smile G Backer
Gerald P. Backer
gpbacker is on a distinguished road
Well, your list is quite restrictive.
WRAFTS is better than any of the three listed codes for the following reasons :
1) The free surface models in WRAFTS are excellent.
2) It is a true FEA program. You are not required to use the vendor's mesh generator. You can use whatever meshing software you have for structural FEA models.
3) Technical support is direct from the author of the code.
4) The price is lower than the codes you have listed.
IMHO
Respectfully,
Gerald Backer
www.wrafts.com
gpbacker is offline   Reply With Quote
Old   October 8, 2009, 14:32
Default Wrafts VOF model
CFDtoy
CFDtoy is on a distinguished road
Hello Backer,
What is the free surface modeling approach used in WRAFTS? I could not find any literature in the website. Could you kindly elaborate?
Thanks,
CFDtoy
IMHO
Respectfully,
Gerald Backer
www.wrafts.com
CFDtoy is offline   Reply With Quote
Old   October 8, 2009, 15:50
Gerald P. Backer
VOF variants, adapted to unstructured grids.
Old   October 12, 2009, 10:04
Default Vof
CFDtoy
Could you kindly explain the base VOF method adapted to the unstrc grids? Is it PLIC type? Any publications on this method will help understand the superiority much better.
Thanks.
How to set pulsatile flow in cfx? bmdaortiz CFX 4 September 8, 2009 22:48
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
CFX For two phrase flow windhair CFX 2 October 22, 2001 03:54
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 2, 1999 23:18
