Help with the discretization of the source term!
Old   September 22, 2009, 03:32
Default Help with the discretization of the source term!
Libo Qian
leotsien is on a distinguished road
Now I am doing numerical research on the turbulence, using FVM and collocated grids arrangement and Low Re turbulence model. Could you tell me how to discreteize the source term for u- v- k- epslion- equation with non-uniform grids.
I've tried a lot of method, but I can't get correct solution. I don't know why?
I'am very grateful for your advice!
leotsien is offline   Reply With Quote
Old   September 22, 2009, 06:09
ztdep's Avatar
p ding
ztdep is on a distinguished road
Send a message via Yahoo to ztdep Send a message via Skype™ to ztdep
which method did you use.
Finite volume method or finite difference method.
in the finite volume method, it is much easier.
ztdep is offline   Reply With Quote
Old   September 22, 2009, 06:18
Libo Qian
Finite volume method!
I don't know how to deal with the source term correctly!
With non-uniform grids
Old   September 22, 2009, 23:51
ztdep's Avatar
p ding
Dear friends:
Since the FVM is used. the grid points are always placed at the center of the control volume.
We only need to evalue the derivative at the interface by iterpolation. we can caculate all the source term.
Could you please detail which source term trouble you.
Regards
Old   September 23, 2009, 00:19
Libo Qian
Dear friends:
Regards
The u- and v- source term!
Actually, I've discretized the source term using FVM and coded it. But the results became divergent sudenly during iteration process. I mean in this step the results is convergent, while it will become divergent next step.
I don't know why?
Should I limit some parameters?
If so, which?
Thank you!
Long for hearing your advice.
Old   September 23, 2009, 00:29
ztdep's Avatar
p ding
which alogirithm did you use. Have you validate your code?
If your code is correct, i think you may try to lower the realxation parameter for u and v.
BY the way, which method did you use to solve the linear algrebra equation.
Old   September 23, 2009, 01:47
Libo Qian
SIMPLER, collocated grid, non-uniform grid
Yes, I've validated my code: lid-driven cavity flow, natural convection in square cavity and so on.
I use ADI to solve the linear algrebra equation.
If I want to simulate turbulent natural convection in a square cavity, the best relaxation factor ? Could you give me some advice?
Thank you!
momentum source term zwdi FLUENT 14 June 27, 2017 15:40
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 13, 2000 23:03
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
