Central Difference Navier Stokes
Old   December 4, 2003, 10:03
Default Central Difference Navier Stokes
Ben
Does anybody have any information on the stability criteria for the one dimensional Navier Stokes equations discretised with a second order central difference scheme without artificial dissipation? I realise that it's a non-linear stability problem, but are there any useful solutions apart from those gained through the model convection-diffusion equation?
Old   December 4, 2003, 10:43
Default Re: Central Difference Navier Stokes
CFDRookie
Grid Peclet Number = Pe = (pu)/(G/dx) < 2 where: p=density (kg/m^3) u=velocity, assuming uniform on one cell end to the other cell end (m/s) G=diffusion coeff. (kg/m/s) dx=characteristic cell width
For a given physical situation, if one is in violation of that criteria, then there's no choice but to reduce 'dx'. This will increase resource demands, however.
Artificial dissipation is not a concern in general for 2nd order C.D. schemes; the main issue is balancing stability and resource constraints.
Filtered navier stokes equation..LES:: Palani Velladurai Main CFD Forum 7 September 6, 2013 02:51
Adding a term to Navier Stokes Equation ashtonJ CFX 3 January 15, 2011 06:32
Specified Blend factor =1 Vs Central Difference Kushagra CFX 4 May 2, 2008 13:14
Navier stokes compresible viscid flow fea, somebody can help? Jose Choy Main CFD Forum 3 October 24, 2003 02:28
Newbie:Viscoelasticity and Navier stokes equation Rajil Saraswat Main CFD Forum 2 June 9, 2003 07:21
