patching problem unsteady solver
hello everybody
i have a problem with the unsteady solver. i am trying to simulate the combustion of propane/air in a channel (length=1 to 5cm, gap size= 0.5 to 1 mm). i am using species transport model, with volume and wall surface reaction. after running several simulations with the steady state solver, i want to look now at the ignition behavior of this mixture. hence i am using the unsteady solver now. this is my problem: i initialize with default values and patch a high temperature in the whole channel; reaction doesn't take place. i initialize with default values, but with a high temperature; reaction takes place, but temperature remains the same (initialized with 1500K --> temperature remains unaffected about 1500K; initialized with 1000 --> temperature remains unaffected about 1000K) what is the reason for this, what am i doing wrong. any suggestions? further i want to patch a high temperature just at the inlet domain. how can i do this? i can just select the channel and the solid wall as a domain. thanks for your help:) |
