FVM-higher order scheme
Old   November 28, 2003, 22:07
Default FVM-higher order scheme
K S Chang
In the code with finite volume method, we want to upgrade the discretization oreder of convective term. Now the schemes in the present code are hybrid and QUICK. What is the higher order scheme than these ? If there is the reference, let me know. Thank you~
Old   November 29, 2003, 08:25
Default Re: FVM-higher order scheme
Anyone.
You can use TVD schemes which are in general 2nd order but will degenerate to 1st order at a discontinuity. However, for convection problems, this is unlikely to be a problem at low speeds. Also, TVD schemes use for convection tend to give a very smooth solution instantaneously. TVD schemes include Van Leer (dissipative) and Superbee (compressive) as well as many others. ENO schemes can also be used. Look for papers by Shu and Osher. I think that these ENO schemes are usually only used for scalar convection not the momentum equations.
Old   November 30, 2003, 19:59
K S Chang
Thank you for your kindness.
I mean that the oder is 3rd order or higher than this.
In FVM, which scheme is higher than 3rd ?
Old   December 1, 2003, 09:22
ag
You can define a higher order upwind biased interpolation function to increase the order of discretization. I have been reading a paper by Tamamidis and Assanis (Numerical Heat Transfer B, Vol. 24, No. 1) that describes a fifth-order upwind scheme. The face value is given by
Uf = (-6Ui-2 + 540Ui-1 + 94Ui+1 - 26Ui+2 + 4Ui+3)/120
and they use QUICK near bundaries.
Old   December 1, 2003, 23:05
K S Chang
Thank you very much~~ It's very useful to me. ^^
Old   December 9, 2003, 05:47
K S Chang
I have one more question. if the grid is non-uniform, above equation can not be applied in my thought ?? In non-unoform grid system, more complex equation is needed ???
Old   December 9, 2003, 10:26
Praveen
You map to a uniform computational domain and then use the same formulae.
divergence with higher order scheme shekharc Main CFD Forum 1 July 23, 2009 13:53
Higher order downwind scheme jelmer OpenFOAM Running, Solving & CFD 4 August 9, 2006 06:43
Switch to higher discretisation scheme ales FLUENT 3 May 25, 2001 10:43
FVM < FEM ? Tony Main CFD Forum 15 May 18, 1999 14:03
second order FD upwind scheme Heinz Wilkening Main CFD Forum 2 November 3, 1998 14:33
