Animation Error in Fluent
Old   October 14, 2009, 02:25
Exclamation Animation Error in Fluent
Andrew
Andrew is on a distinguished road
Hi Everyone,
I am simulating flow over a square cylinder in 3D and trying to create animations of the vortex field.
I am applying the animations through: Solve/Monitors/Animations.
However, when the simulation finishes and I try to playback the animation to write the mpeg, I get this error:
"mpeg_encode param1"
MPEG ENCODER STATS (1.5b)
TIME STARTED: Wed Oct 14 16:45:48 2009
MACHINE: unknown
FIRST FILE: .\/velocity-magnitude-1_1_0000.ppm
LAST FILE: .\/velocity-magnitude-1_1_0199.ppm
PATTERN: i
GOP_SIZE: 12
SLICES PER FRAME: 1
RANGE: +/-8
PIXEL SEARCH: FULL
PSEARCH: EXHAUSTIVE
BSEARCH: CROSS2
QSCALE: 8 8 8
REFERENCE FRAME: ORIGINAL
Input file too small! (ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ)
Removing frame files ... done.
If anyone can help with this error and why it occurs, it will be greatly appreciated.
Thanks.
Andrew
Andrew is offline   Reply With Quote
Fluent - license problem. Marcin FLUENT 3 April 13, 2018 16:33
Integration of a Custom C++ Model into FLUENT Syed Haider FLUENT 2 March 6, 2018 23:37
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 19:12
On Bug of Fluent 12.0 lzgwhy FLUENT 0 August 26, 2009 06:41
Running fluent in UNIX L3munoz FLUENT 10 August 26, 2009 04:59
