Turbulence on collocated grid
Old   October 11, 2009, 07:01
Thumbs up Turbulence on collocated grid
MAZI
mazdak is on a distinguished road
Hi dear readers.
as you know when you use finite volume method, for turbulent flow,you need to fix k and epsilon at nodes that wall function are applied trough below method:
Su=(10^30)*...
Sp=-(10^30)
I wanna to know when we use a collocated grid do we need this treatment for U-velocity when we use wall-function?
and is there anyone write a code for turbulent flow in channel in a collocated grid?
mazdak_parsi2000@yahoo.com
I am waiting for your helps.
mazdak is offline   Reply With Quote
Old   October 12, 2009, 03:29
Mohammad Reza Hadian
hadian is on a distinguished road
you should calculate the U at the nearest cell to wall and add the shear stress of the wall to the source term for that cell. there are some tricks for adding the stress. have a look on the book by Versteeg and Malalaskera.
hadian is offline   Reply With Quote
Old   October 12, 2009, 04:08
Default Collocated
MAZI
thanks Mr.hadian but what you say is for staggered grid nor to collocated grid.i study that book.thanks
Old   October 12, 2009, 10:49
do you mean the u-cell near the south or north wall? so it is the same as staggered grid. for v-cell near north and south wall the method is a little different.
Old   October 13, 2009, 03:46
MAZI
imagine an horizontal channel.as you know, when you use collocated grid, all variable u,v,p,k,ep calculated at same cell.
as you study versteeg's book, you know that because some nodes are outer of walls.i mean we have not any nodes on wall for staggered grid.so the effect of wall, modeled by adding a source term to Sp in u-equation.
in this added source term u-plus is available.if y-plus be less than 11.62 we treat it, in a way and if y-plus be greater than 11.62 we treat it in another way.
my question is when we use collocate grid how do we treat for wall function?
if you are live in iran and you know any thing about using wall function for collocated grid i call you
Old   October 13, 2009, 07:58
in collocated grid you have a cell out of the wall. that is exactly the same as staggered grid.
www.hadian.ir
Old   October 13, 2009, 14:19
Default Oooooooooooooh realy
MAZI
Hi Dr.hadian
i didn't know really this point.but the generated by me has this properties:
imagine a south wall. i put first row of nodes on wall.second row of nodes puted upper than those and after second row, i put north cell face of cv.
like this
------------(north cell face of cv)
................. (second row of nodes)
................(south wall nodes)(first row of nodes )(south cell face of cv)
i mean i don't put any nodes out of wall and use this form of grid to form complete cv.
what's your opinion about this type?
Old   October 13, 2009, 15:44
because of boundary condition you should have extra nodes in your domain. one method is to have dummy cells out of boundary (as it is described by Vesteeg and Malalaskera) the other one is to pot extra nodes on boundary. in the second form you do not have cells beyond the domain but there will be some cells with more than one node (one at the center of cell and one on the cell face). i think the first method is more straitforward.
Old   October 14, 2009, 11:34
MAZI
Hi dear Dr.Hadian
i choose 2nd form of grid that you mentioned.question is about imposing boundary condition for u velocity and utlizing of wall function.i use
Rhi-Chow for eliminating pressure hardship when we calculate all variables at same node.and if you can send your cell phone number in my email address to call you.
Old   November 1, 2009, 04:19
MAZI
Hi dear Dr.Hadian
could you tell me how must i treat for the V near the wall in collocated grid?
and if you have any paper in this field pleas send me.
be in success.
Old   November 1, 2009, 06:13
you can calculate the V at cell near south or north wall in your calculation. for calculating the coefficients you will refer to values at the cell beyond the wall. after calculating V at cells. use -V of the cell next to wall for the cell beyond the wall. In this way V=0 in implemented on the wall automatically.
Old   May 23, 2011, 01:59
jk
jyothishkumar is on a distinguished road
Dear Hadian,
I have cfd code for laminar flow (channel flow) with colocated grid arrangement. I have implemented k epsilon turbulence model in to this. Now if i see my velocity profile (coming as expected) i found that it is more peakier than that of a laminar profile. Also the pressure at the inlet increasing like anything. Details are as follows
My boundary conditions : Velocity inlet, pressure outlet and wall (top and bottom).
And I have followed the book versteeg and malalasekara. Also I have compared my laminar flow results with FLUENT code and found it is matching but i am getting this peculiar problem for turbulent flow. Please tell me your valuable suggestion.
thanks in advance
jyothish
jyothishkumar is offline   Reply With Quote
Thread Tools
Trackbacks are On
Collocated grid (Rhie and Chow) C.Robin Main CFD Forum 5 February 29, 2008 04:19
Paraview file format for collocated grid hadian ParaView 0 February 13, 2008 10:55
collocated grid jj Main CFD Forum 6 June 25, 2007 13:26
Staggered Vs Collocated grid Sas Main CFD Forum 6 June 21, 2007 10:34
Re: paper: Turbulence modelling without grid. Jaykov Foukzon FLUENT 0 October 27, 2005 00:47
