problem in using MRF model
Old   October 12, 2009, 08:45
Default problem in using MRF model
haamed mohajer
haamed is on a distinguished road
we are analysing a wind turbine with Fluent, we tested 2 models for rotating turbines(MRF& moving walls for blades). But the results of MRF model is completely out of range.
we will appreciate you if you guide us.
haamed is offline   Reply With Quote
problem with UDF for (v2-f) turbulence model in fluent artemiss1984 Fluent UDF and Scheme Programming 6 January 17, 2014 05:50
problem of dynamic mesh for a piston model pipin Fluent UDF and Scheme Programming 2 August 2, 2010 14:35
A Problem with setting the time step in VOF model Le FLUENT 2 July 20, 2006 22:00
Non premixed model - combustion validation problem David FLUENT 2 October 24, 2003 10:06
Two phase Eulerian Model Problem senthil FLUENT 5 May 21, 2003 02:55
