October 16, 2009, 09:33 |
C - Fortran Interoperability
Rep Power: 17 |
Hi all
Does anybody knows how to send a linked list from fortran to C, allocate this list in C and then recover the data in fortran? Thanks in advance Marcio |
October 16, 2009, 11:56 |
andy
Rep Power: 17 |
Fortran-C interfaces vary from compiler to compiler. You will have to look in the manual for the details for your particular compiler.
It may also help if you state why you want/need to use C to "allocate this list" and what that means exactly when you are mixing the two languages. The C approach and the Fortran approach for handling state are different. And what version of Fortran are you using? |
October 16, 2009, 12:58 |
Rep Power: 17 |
Hi, andy_. Thanks for your reply.
I'm working with intel compilers, version 11.1.046 for both C and Fortran. For C-Fortran interface I'm using the intrinsic module iso_c_binding. Here's the situation: We have a solver for multiphase flows based on Structured Adaptive Mesh Refinement (SAMR) which is written in Fortran. The interface between fluid phases will be modeled with front tracking. The geometric representation of the front tracking will be done with the GNU Triangulated Surface Library (GTS), which is written in C. That is: normal and curvature computing, surface smoothing/remeshing, among other tasks will be performed by GTS. The problem is that the SAMR code is heavily dependent on linked lists. Therefore, sending information from GTS to the SAMR code requires linked lists. Since the main code is Fortran, I have to create the linked list variable in the fortran part, then send it as an argument to the C function which will insert the information in it. Inside the C function everything works fine, and the information is added to the list. However, when I attempt to retrieve the data inside the fortran code I get just thrash data. The C function receives a c_ptr variable to represent the list. Then, in the fortran part, I use c_f_pointer to transfer the data to the actual linked list. I wrote the relevant part of the code bellow: type(c_ptr) :: plist type(list), pointer :: pointer_list type(list), target :: target_list ! ...... call get_gts_mesh(file_name, plist) ! ...... call c_f_pointer(plist, target_list, [list_size]) pointer_list => target_list do if(.not.associated(pointer_list%next)) exit ! !do some work with the list data ! pointer_list=>pointer_list%next end do Any help will be wellcome TIA Marcio |
October 16, 2009, 16:36 |
andy
Rep Power: 17 |
I am not familiar with the details so please bear this in mind.
Are you expecting a single call to c_f_pointer to convert all the pointers inside the list from C pointers to Fortran pointers rather than simply the single base pointer? Is the structure of the list elements the same in the C code and the Fortran code? If so, how is this achieved? |
October 19, 2009, 06:04 |
Rep Power: 17 |
Actually I expected c_f_pointer could convert the entire list, but it surely does not. As for the structure, I create the struct and function in C. In the fortran part I just create a subroutine interface in which the list is declared as a c_ptr (which is defined in the module iso_c_binding) type. It works fine if I use arrays instead of lists, even if the arrays vars are declared in the fortran part and allocated in the C part.
c-fortran, fortran, linked list |
Double precision & User Fortran | Martijn | CFX | 3 | April 4, 2009 05:43 |
Intrinsic Procedure 'ISNAN' in GNU FORTRAN 77 | hawk | Main CFD Forum | 1 | April 12, 2005 22:13 |
visual fortran | Monica | Main CFD Forum | 1 | August 28, 2004 20:45 |
Fortran77 or Fortran 90 | Swapnil | CFX | 2 | November 26, 2002 15:16 |
Why Favoring Fortran over C/C++? | Zi-Wei Chiou | Main CFD Forum | 35 | September 26, 2001 09:34 |
