-   -   mode of a data set (http://www.cfd-online.com/Forums/main/6934-mode-data-set.html)
m malik December 17, 2003 09:54
mode of a data set
Specifically, my problem is finite element mesh related: finding the maximum number of elements that share a common node. I guess it is basically a problem of finding the mode of a large set of numbers. Would like to know of some C/C++/Fortran code for this purpse. Thanks.
Ananda Himansu December 17, 2003 14:50
Re: mode of a data set -- fortran pseudocode
! answer by enumeration, message board reformats my post by weird rules, forces me to use double-line spacing below
subroutine max_cells_of_nodes (max_cells, num_elements, num_nodes, max_vertices, num_vertices, nodes_of_elements)
implicit none
! global variable declarations follow
! global variables except for max_cells are assumed to be assigned values in calling routine before calling current routine
integer :: max_cells, num_elements, num_nodes, max_vertices
! (max_vertices = maxval(num_vertices))
integer, dimension(num_elements) :: num_vertices
integer, dimension(max_vertices, num_elements) :: nodes_of_elements
! local variable declarations follow
integer, dimension(num_nodes) :: num_cells
! num_cells is an auxiliary array to track number of elements incident on each node
integer :: element, vertex, this_node
do element = 1, num_elements
do vertex = 1, num_vertices(element)
this_node = nodes_of_elements(vertex, element)
num_cells(this_node) = num_cells(this_node)+1
end do
end do
max_cells = maxval(num_cells)
! max_cells is the maximum number of elements that share a common node
end subroutine max_cells_of_nodes
Nashat December 17, 2003 14:59
Check out Rainald Lohner's book:
Applied CFD Techniques: An Introduction Based on Finite Element Methods.
Ananda Himansu December 19, 2003 16:37
whoops, of course there is a bug in my code :) that's what you get for programming in a hurry and not testing!
i forgot to initialize the num_cells array. the following statement should be inserted just before the "do element = 1, num_elements" loop:
num_cells = 0
m malik December 20, 2003 10:18
Thanks. I had noticed that in your first mail.
