How i can speed up my fortran code
Old   December 20, 2003, 19:32
Default How i can speed up my fortran code
cfd student
Any help would be appreciated I would like to speedup my fortran 90 code execution, can i do something in build setting to reduce the execution time?. cfd student.
Old   December 20, 2003, 23:55
Default Re: How i can speed up my fortran code
Peter Attar
A lot of things can be done..depending on your compiler you can set compiler flags so as to see where your bottleneck is..ie which routines are taking up most of the execution time. Then you can concentrate on making those routines faster. Also you can play around with compiler flags which can be used to optimize the code for speed.
Old   December 21, 2003, 03:08
cfd student
Thanks peter .
Old   December 21, 2003, 03:09
cfd student
Thanks peter Altar.
Old   December 22, 2003, 09:38
Praveen
Use some optimization flags like -O or -O2. Many of the optimization flags are not recommended for numerical computations. Read the fortan manpage for more info.
Old   December 22, 2003, 12:55
Steve
and....
It sounds obvious, but it's a common mistake. Make absolutely sure you've not got debugging or profiling activated.
Thread Tools
Trackbacks are On
SIMPLE (or SIMPLER) fortran code Francesco Di Maio Main CFD Forum 5 March 6, 2014 01:54
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
fortran program code jangolobow Main CFD Forum 0 July 11, 2009 05:28
Best Code for User Fortran worth Main CFD Forum 4 November 14, 2003 11:21
I need help for parallalising of fortran code Mahibooswami Main CFD Forum 5 June 11, 2003 07:54
