y+ and surface roughness
Old   October 31, 2009, 13:54
Default y+ and surface roughness
RobT
zebG is on a distinguished road
Starting with a model which has a yPlus less than 9 when a surface is smooth, if I change the surface to 1mm roughness, the y+ increases by a factor of 10. Does this mean that the mesh needs to be refined again to reduce the y+ or does the inevitability of the high y+ reduce the importance?
Basically, has everyone found it to be the case that a low y+ as important with a smooth as a rough model?
I assume that the answer's yes, but just wanted to check before increasing simulation time significantly.
zebG is offline   Reply With Quote
Surface roughness in Flow-3d Marco FLOW-3D 3 June 3, 2018 02:15
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
