How to calculate the convergence rate of Gauss-Seidel line iteration?
Old   November 2, 2009, 22:08
Default How to calculate the convergence rate of Gauss-Seidel line iteration?
Edison
hadesmajesty is on a distinguished road
For the two dimensional Poisson’s equation,
a(d2vdx2)+c(d2vdy2)=0
second-order centered difference with uniform grid is used to discretize. Then, we can obtain
a[v(n,i+1,j)-2v(n+1,i,j)+ v(n+1,i-1,j)]+c[v(n+1,i,j+1)-2v(n+1,i,j)+ v(n+1,i,j-1)]=0
where a<<c (e.g. a=0.01, c=1), hence y-line iteration should be used.
By using the Fourier expansion of the above equation, we can obtain the convergence rate mu(alpha,beta) as
mu(alpha,beta)= | a/[ 2(a+c)-c*cos(beta)-exp(I*alpha) ] | .
According to some book, the maximal value of the above equation is
max(mu)=max{1/sqrt(5), a/(a+2c)}.
I can’t understand how to calculate max(mu). Anybody know? I have tried to analyze the eigenvalues of my iteration matrix, the one with maximal norm is about 0.005, however, the convergence rate in my actual numerical experiment is closed to 1/sqrt(5). How to calculate the convergence rate 1/sqrt(5) theoretically?
Thank you so much.
hadesmajesty is offline   Reply With Quote
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
[blockMesh] BlockMeshmergePatchPairs polyTopoChanger benru OpenFOAM Meshing & Mesh Conversion 3 June 29, 2008 21:24
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
