How to create rotating flow????
Old   November 6, 2009, 01:52
Default How to create rotating flow????
TAS
Tom Steen
TAS is on a distinguished road
Hey all,
This is my first post and it is out of some desperation...
I have been trying to create a working CFD simulation for the following case. I have a Helical Aerofoil (spiral) and I need to perform a CFD analysis on it.
The case i need to setup is as if the aerofoil is rotating at a high tangential velocity, as well as moving forward. To help you imagine what I am talking about...Look at this...
http://en.wikipedia.org/wiki/File:Ecoli_flagellum.jpg
I attempted to create a Cylidrical Control Volume, with walls set as Symmetry, an Outflow and a Velocity Inlet. I set the velocity inlet to apply an Axial Velocity and a rotational speed. The issue is, at the edge of the control volume I get the flow rotating correctly and moving in the right direction, however through the centre of the cylinder I have a helical flow reversal, where the Axial velocity is moving the wrong way.
As far as it being a suitable control volume for the analysis, it isnt. Does anyone have any ideas as to what kind of Mesh, Boundary Conditions and anything I need to successfully Model the flagellum...?
Someone mentioned to me to use a dynamic mesh that rotates, however I have no idea how to use it...
Any help will be great.
Thanks
TAS
PS: I am using GAMBIT and FLUENT (and i have already overcome the geometry import issues with GAMBIT)
TAS is offline   Reply With Quote
Rotating Flow Problem Carlos Riaņo Main CFD Forum 6 July 15, 2004 18:57
secondary flow in rotating flow mahesh Main CFD Forum 0 May 25, 2004 05:35
axial flow in counter rotating ducted fan Vishu FLUENT 4 January 13, 2004 18:52
about swirling flow in rotating frame of reference Sijal Ahmed FLUENT 0 December 27, 2003 11:21
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 06:18
