[Sponsors] | |||||
lostin
Rep Power: 5 ![]() |
Hi all..
I am trying to simulate a free motion of water in a rectangular tank. I have taken water(second phase) in some initial distorted form and now I want to simulate its free motion in tank. I am using interfoam for this. After running interFoam I am getting this error... Build : 1.6-53b7f692aa41 Exec : interFoam Date : Nov 15 2009 Time : 00:08:29 Host : lostin PID : 19839 Case : /home/akash/OpenFOAM/akash-1.6/run/multiphase/interFoam/laminar/8cm_unforced nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Reading field p Reading field alpha1 Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type laminar time step continuity errors : sum local = 0, global = 0, cumulative = 0 GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 7.12628e-12, No Iterations 1 time step continuity errors : sum local = 3.34444e-09, global = -1.69132e-27, cumulative = -1.69132e-27 Courant Number mean: 2.51417e-09 max: 4.04544e-07 Starting time loop Courant Number mean: 5.02834e-08 max: 8.09087e-06 deltaT = 0.1 Time = 0.1 MULES: Solving for alpha1 Liquid phase volume fraction = 0.2 Min(alpha1) = 0 Max(alpha1) = 1 MULES: Solving for alpha1 Liquid phase volume fraction = 0.2 Min(alpha1) = 0 Max(alpha1) = 1 MULES: Solving for alpha1 Liquid phase volume fraction = 0.2 Min(alpha1) = -1.16775e-40 Max(alpha1) = 1 mesh flux field does not exists, is the mesh actually moving? From function fvMesh: hi()in file fvMesh/fvMeshGeometry.C at line 336. FOAM exiting I am searched a lot but could not find solution of this error. I am using 1.6 version. ![]() Thanks in advance.. |
Pei-Ying Hsieh
Rep Power: 7 ![]() |
hi guys, i have a problem with the surface tension implementation!
like the tutorial:free surface flow over a bump. i have a film(polymersolution) over a platt with 2 diferent temperatures,length scale 50 mm,laminar other settings and the boundarys condition are the same like in the tutorials. i have to get the surfacetension-curve as funktion of the temperature! what i should to do? thank a lot |
Pei-Ying Hsieh
Hi, lostin4ever,
Since you are using interFoam, so, I assume that you are not running moving mesh. In your 0/U, change wall type to fixedValue and in constant/dynamicMeshDict change it to staticMeFvMesh you should be able to run your case after the two changes. Pei |
mohsen kh
Rep Power: 4 ![]() |
Hi every body,
I have a problem when I want to compile a model. the error is: ************************************************** ********************* ************************************************** ********************* viscoelasticLaws/mohsen/mohsen.C:159: error: no match for ‘operator==’ in ‘Foam: perator+(const Foam::tmp<Foam::fvMatrix<Type> >&, const Foam::tmp<Foam::fvMatrix<Type> >&) [with Type = Foam::SymmTensor<double>](((const Foam::tmp<Foam::fvMatrix<Foam::SymmTensor<double> > >&)((const Foam::tmp<Foam::fvMatrix<Foam::SymmTensor<double> > >*)(& Foam::fvm::div(const Foam::surfaceScalarField&, Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) [with Type = Foam::SymmTensor<double>](((Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>&)(&((Foam::mohsen*)this)->Foam::mohsen::a_))))))) == Foam: perator+(const Foam::tmp<Foam::GeometricField<TypeR, PatchField, GeoMesh> >&, const Foam::tmp<Foam::GeometricField<Type1, PatchField, GeoMesh> >&) [with Type1 = Foam::Tensor<double>, Type2 = Foam::SymmTensor<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >&)((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >*)(& Foam: perator*(const Foam::dimensioned<double>&, const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = Foam::SymmTensor<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >&)((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >*)(& Foam: perator&(const Foam::tmp<Foam::GeometricField<TypeR, PatchField, GeoMesh> >&, const Foam::tmp<Foam::GeometricField<Type1, PatchField, GeoMesh> >&) [with Type1 = Foam::SymmTensor<double>, Type2 = Foam::SymmTensor<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >&)((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >*)(& Foam: perator-(const Foam::dimensioned<Type>&, const Foam::tmp<Foam::GeometricField<Type1, PatchField, GeoMesh> >&) [with Form = Foam::SymmTensor<double>, Type = Foam::SymmTensor<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >&)((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >*)(& Foam: perator*(const Foam::scalar&, const Foam::GeometricField<Type, PatchField, GeoMesh>&) [with Type = Foam::SymmTensor<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>&)((const Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>*)(&((Foam::mohsen*)this)->Foam::mohsen::a_))))))))))))))))))))’************************************************** ************ ************************************************** ************ and the model is : // Velocity gradient tensor volTensorField L = fvc::grad( U() ); // Convected derivate term // volTensorField C = tau_ & L; // vorticity term volTensorField Vor = L - L.T(); // Twice the rate of deformation tensor volSymmTensorField twoD = twoSymm( L ); // fc scalar fc = 0.5; //1 - 27 * det( a_ ); //double dot term // volSymmTensorField mk = -( (2 / 35) * ( 1 - fc ) * twoD - (2 / 7) * ( a_ & twoD + twoD & a_ + (1 / 2) * tr( twoD & a_ ) * I_ ) - fc * tr( twoD & a_ ) * a_ ); // Stress transport equation tmp<fvSymmTensorMatrix> aEqn ( fvm::ddt(a_) + fvm::div(phi(), a_) == ( 1 / 2 ) * ( Vor & a_ - a_ & Vor ) + ( 1 / 2 ) * keisi_ * ( twoD & a_ + a_ & twoD + 2 * ( ( (2 / 35) * ( 1 - fc ) * twoD - (2 / 7) * ( 1 - fc ) * ( a_ & twoD + twoD & a_ + (1 / 2) * tr( twoD & a_ ) * I_ ) - fc * tr( twoD & a_ ) * a_ ) ) + 2 * ci_ * twoD & ( I_ - 3 * a_ ) //+ twoSymm( C ) //- zeta_ / 2 * ( (tau_ & twoD) + (twoD & tau_) ) //- fvm::Sp( epsilon_ / etaP_ * tr(tau_) + 1/lambda_, tau_ ) ); aEqn().relax(); solve(aEqn); // Viscoelastic stress tau_ = (etaP_ / keisi_) * (a_ - I_); } ************************************************** **************** ************************************************** **************** where "a" , "tau" and "I" are symmetric tensors and "Vor" is asymmetric tensor. and the others are constant parameters. Best |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Thermocapillary free surface flow | zakifoam | OpenFOAM Running, Solving & CFD | 5 | May 20, 2009 13:23 |
| Tensions on free surface interFoam | sega | OpenFOAM Running, Solving & CFD | 0 | April 29, 2008 14:26 |
| VOF simulation free surface caused by gas inject | rensb | FLUENT | 4 | July 20, 2006 04:45 |
| Variable Density - Free Surface with FIDAP | Vitaliy Pavlyk | FLUENT | 7 | May 2, 2000 15:56 |
| Modeling Free Surface Flows | Elliot Schwartz | Main CFD Forum | 5 | August 25, 1998 21:03 |
