The K-e Model
Old   November 14, 2009, 17:52
Default The K-e Model
Walid JARRAH
wjarrah is on a distinguished road
Send a message via MSN to wjarrah Send a message via Skype™ to wjarrah
Hello everyone,
I have to study the k-e model, i would appreciate it if you could help me with these questions :
- When do we use it ? ( It is adapted to which situations?)
- Pros/Cons
- What do these constants 'C_mu, 6_epsilon, C1e, C2e' match correspond to ?
- When do we have to change them ?
- What are the conditions to have good results? (y+ = 1 in the first cell ?!)
- And if possible, a comparison with the K-Oméga SST, V˛_f et Reynolds Stress models ?
Thanks a lot !
wjarrah is offline   Reply With Quote
Old   November 15, 2009, 22:47
Charles Rundle
Charles Rundle is on a distinguished road
I'm afraid I'm not sure how familiar you are with turbulence models so if I repeat what you know please forgive me.
The k-epsilon turbulence model is a two equation eddy viscosity model similar to the k-omega and SST models. Actually the SST model is a blending of the k-epsilon and k-omega models designed to minimize the weakness of both models. That's not the only thing that makes SST different but it is the most relevant to your question.
My understanding is that the k-epsilon model is best in free flows away from the walls. It also has a tendency to model separation
flows poorly and can over predict turbulence in stagnant areas. The other limitations of eddy viscosity models also apply. That being said it is possible to adapt to other situations.
With regard to the constants they can be adjusted to correct for different types of flow. If you’re interested in a specific type of flow I recommend searching academic journals. You should be able to find articles that will help you with the correct values for constants.
It would be helpful to know which k-epsilon model you are considering. i.e. is a Low Re model or are you using a wall function.
I should mention that while I believe everything I have presented is correct I do not guarantee it as such or accept any liability that may arise from its use. It is entirely my opinion and you use it at your own risk.
Hope I was helpful. Have a good day.
CAR
Charles Rundle is offline   Reply With Quote
Old   November 16, 2009, 01:10
N/A
harishg is on a distinguished road
The constants in the model depend on the test cases that have been used to obtain them. Depending on the choice of the authors different models consider different test cases. Hence you would find slight differences in the model constants for the same k-e model. Usually you use y+<=1 to ensure the grid independent solution. You need to ensure that you use a low-Re model if you integrate through the viscous sub layer. Regarding the models that you are considering as k-omega SST and RSM have been shown to perform much better than k-epsilon models for many test cases. However, recently many new k-e models have been proposed which may be as good as these two models.
harishg is offline   Reply With Quote
Old   November 16, 2009, 07:24
Walid JARRAH
Thanks Charles and Harishg !
Old   November 16, 2009, 08:41
Charles Rundle
You are most welcome.
Have a good day.
CAR
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 06:19
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 10:27
references about the fan/radiator model Mihai ARGHIR Main CFD Forum 1 January 8, 2001 15:49
references about the fan/radiator model Mihai ARGHIR Main CFD Forum 0 December 21, 2000 03:06
references about the fan/radiator model Mihai ARGHIR Main CFD Forum 1 December 17, 2000 07:01
