Coding in Fortran95
Old   November 16, 2009, 17:59
Default Coding in Fortran95
Mohammad
Moradi is on a distinguished road
I am doing coding. I use Fortran95.
I have some subroutines which contains optional arguments.
When I call them I can use "if () then" or "select case()" to choose whether assign data to these optional arguments or not. As I know even if I assign an undefined data (undefined array; e.g. an allocatable array which i not allocated) to these subroutines, program will not encounter any problem.
My question is: should I actually use a criterion (using "if" or "select case") when I assign data to these subroutines (for example: when I have an allocatable array I can use "if"; so, when the array is not allocated I will not assign it to the optional argument. But, is it necessary)?
Thanks so much.
Moradi is offline   Reply With Quote
Old   November 24, 2009, 13:31
ztdep's Avatar
p ding
ztdep is on a distinguished road
Send a message via Yahoo to ztdep Send a message via Skype™ to ztdep
generally, we set it to a default value ,such as 0 to avoid some zero.
ztdep is offline   Reply With Quote
Old   November 24, 2009, 13:53
Default Hi
Mohammad
First of all, thanks for giving me some comments.
Yes, that is right. But, what if this variable (an array) is not allocated (if I can ignore allocation of an unnecessary array , I can save the memory[assume I am solving for laminnar flow. So, alocation of turbulence related variables will be unnecessary]). My question actually is about such cases.
Thanks so much Ztdep
Old   November 24, 2009, 20:57
ztdep's Avatar
p ding
if(Solve Turbulent) then
Allocate( Turbulent related variables )
Else
Allocate( laminar flow related variables
endif
Thread Tools
Trackbacks are On
Varibales for user coding Tomo STAR-CCM+ 3 September 10, 2009 03:49
Help with coding James Main CFD Forum 2 May 18, 2005 05:12
Coding begineer of cfd Main CFD Forum 1 July 21, 2004 05:11
Ground coding enquiry Wenqing Zhang Phoenics 2 August 12, 2002 11:56
User coding on NT w2k Philip Jones CD-adapco 0 November 26, 2001 04:43
