flotran
Old   January 15, 2004, 21:15
Default flotran
Ann
Hi, I'm young student from Poland and I've started work with ANSYS not long ago. I'm trying to run a problem with flotran using the element 142 but with moving wall (just like in ANSYS tutorial- 7.6. ALE/VOF Analysis of a Vessel with a Moving Wall). I would like to know how I must set correctly displacement, because probably the problem starts there. Thank you!!!
Ann
Old   January 16, 2004, 13:15
Default Re: flotran
Roger Yang
You need to specify both displacement and velocity in time domain on the moving walls. The Tortional Mirror problem in Sec 7.5 gives more details. Also look into the input command file. I remember those loads are generated using a "Function Builder".
Ansys FLOTRAN. Remeshing according velocity vectors or streamlines? pablo--- ANSYS 2 December 11, 2009 04:35
ansys flotran error message Alf ANSYS 0 September 4, 2009 18:49
ansys flotran error message HELP!! atmcfd Main CFD Forum 0 June 22, 2009 02:27
Flotran problems with compressible turbulent flows Ross Main CFD Forum 1 September 27, 2002 13:08
Flotran Arvind Main CFD Forum 0 May 15, 2002 18:10
