Wall boundary condition in cylindrical co-ordinate |
December 2, 2009, 00:11 |
Chandra
Rep Power: 16 |
I am a bit confused about application of the wall BC at solid walls in cylindrical co-ordinate on staggered grid. For the imaginary cells, the lateral velocity components v,w are set as negative of the adjacent inner cell to keep these zero on the wall. The normal component u of this imaginary cell is determined from "Div = 0" at the wall. i.e. DEL.V = 0 on the wall. However, v,w = 0 on the wall. So, this becomes: [d(ru)/dr] = 0 ---- (1) If r_i defines the cylindrical boundary and we discretize this, it gives: u_(i+1) = [r_(i-1) / r(i+1)].u_(i-1); which is quite right. However, if we take the equation (1) further, it gives: du/dr + u/r = 0. Since u = 0 at the wall, it becomes, du/dr = 0 i.e. u_(i+1) = u_(i-1), which is wrong in cylindrical co-ordinate. Where is the mistake? Thanks! |
December 2, 2009, 00:21 |
Since u = 0
du/dr .NE. 0 u has gradient near the wall. |
December 2, 2009, 02:28 |
Chandra
Rep Power: 16 |
Thanks! What you are saying is surely the case. However, why does the divergence-free condition lead to that incorrect condition? What's wrong?
December 2, 2009, 08:20 |
I think the problem is that the continuity equation is used for fluid. not for the wall
How to set rotating wall as boundary condition | babu | FLUENT | 7 | December 14, 2013 04:48 |
Change wall boundary condition in multiphase? | Jacques | FLUENT | 0 | November 27, 2008 06:26 |
Wall boundary condition – UDF | Ssn | FLUENT | 0 | January 25, 2008 03:43 |
Variable temperature wall boundary condition | Virginie | FLUENT | 2 | October 2, 2007 09:23 |
the boundary condition of permeable wall | lisa | FLUENT | 12 | May 5, 2005 20:58 |
