May 9, 2006, 10:13 |
hexahedra elements & accuracy???????
Hello friends. I have a question. Is there any relation between the type of element used and the accuracy?? I am using CFX software. In the help files, it has not been given. Please help me. Regards, VVJ.
December 3, 2009, 13:01 |
hexahedral vs tetrahedral
Serval professors have informed me that a Hexahedral mesh is more acurate in the boundary layer. Tetrahedrals have less skew computational issues and are better over irregular geometry or when expanding the size of the cells away from the geometry(size function).
I am curious however as to how much more accurate they are; since in the opensource world tetrahedrals are much easier to generate. (Anyone) Do you think it would take twice as many tetrahedrals, three times as many, four, or more to be equivalent to the quality of a hexahedral boundary layer mesh? |
December 3, 2009, 16:12 |
Charles
Rep Power: 18 |
Well, in real life this is actually a very complex question with no simple answer. There are theoretical methods that should give you the relative accuracies, but in my experience practical concerns tend to override these. For example, it can depend on the topology of whatever it is that you are meshing. When it comes to something very regular like a 3D wing, for example, a tetrahedral grid may require 10 times as many cells as a hexa grid, for equivalent accuracy.
It is also noticeable how fast certain types of unstructured hexa grids will converge, by virtue of minimal skewness and good cell aspect ratios. I have sometimes seen a poor quality hexa grid produce better results than a good tetra grid. It rather depends on where the bad cells are, and how resistant the solver is to being tripped up by these bad cells. |
December 3, 2009, 16:32 |
Rep Power: 17 |
Can I refer you to this paper by Hefny and OOka: CFD analysis of pollutant dispersion around buildings: effect of cell geometry, Building and Environment 44 (2009)
December 4, 2009, 14:37 |
hexahedral mesh is _x as acurate
Thanks CapSizer! You are the first person to put forth a number. 10 times means a whole lot more than "more". Im not going to base any calcultions on it, but it is good to have a feeling for the numbers before you choose a direction.
Thanks for the ref kingjewel1. Here is the abstract if anyone else is interested: http://cat.inist.fr/?aModele=afficheN&cpsidt=21358896 If anyone else has had different experiences please post them. Thanks! |
Temporal accuracy | ganesh | Main CFD Forum | 0 | February 29, 2008 05:32 |
Hexahedran elements and accuracy???? | vijesh joshi | CFX | 0 | May 9, 2006 10:14 |
Penetrating elements in extruded mesh | Michael P | CFX | 2 | May 20, 2005 08:06 |
accuracy of Discontinuous Galerkin | Qu Kun | Main CFD Forum | 0 | September 6, 2004 09:19 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
