Impinging jets - Secondary maxima issue
Old   February 6, 2004, 00:48
Default Impinging jets - Secondary maxima issue
John
I am trying to simulate 2D slot and 3D square impinging jets(free and confined) with FLUENT. At low nozzle-to-plate spacings and at high Re(say H/W<2, Re_W>10000), experimental data shows an off-center peak in the skin-friction factor and Nu profiles. I tried all the k-eps and RSTM cases (steady) with the standard and enhanced wall functions, but cannot capture those secondary peaks. The nozzle exit BC's are 1-10% turbulent intensity and a turbulence length scale of 0.07W. I also tried the case with fully developed turbulent flow between two parallel plates in the case of slot jets(using k and eps profiles obtained from the flow between parallel plates at the nozzle exit) as the nozzle-exit condition but didn't work either. Any suggestions? Will unsteady simulations help?
Thank you in advance.
John
p.s. Is there anybody running LES using Smagorinsky model and getting good agreement?
Old   February 6, 2004, 01:32
Default Re: Impinging jets - Secondary maxima issue
andrew
the secondary peaks in the Nu profile are due to turbulence generation and are not picked up by the standard models. there is an extra turbulence model available, the v2f model, which is designed to correctly model impinging jets. (this requires an extra licence, for a fee). I am in the process of getting this model at the moment, so i don't know how well it works.
Have you tried the LES model, i would like to know if this works. (at the moment i am doing 2d models so i can't use it)
some links for the v2f model are
http://www.turbulentflow.com/
http://www.fluent.com/software/fluen...turbulence.htm
regards andrew
Mesh generation in impinging jets azurespirit Main CFD Forum 9 January 20, 2011 20:22
Water quenching with impinging jets Rockda Main CFD Forum 1 September 6, 2010 23:20
Summer Course on ''Jets in Cross-Flow'' alfredo soldati Main CFD Forum 1 May 5, 2001 21:34
a low Re number model for impinging jets mahesh prakash Main CFD Forum 14 September 3, 1999 16:40
IMPINGING JET ........... HELP!!!!!!!! Amir Omoumi Main CFD Forum 10 August 30, 1999 22:11
