-   -   Memory stack-Fortran vs Windows XP (http://www.cfd-online.com/Forums/main/7110-memory-stack-fortran-vs-windows-xp.html)
Mikel A. February 5, 2004 13:09
Hi, I have been running our code up to 1.5GB RAM size in my computer. It has 2.56GB RAM available. I have tried unsuccesfully to run a 2.06GB simulation and Windows XP gives the error: it is not a win32 application. Does anyone know how to make Windows XP go over 2GB RAM?
Thanks!!
Mikel Alonso
Raul February 5, 2004 14:28
Re: Memory stack-Fortran vs Windows XP
Hola
What's the (company) name of the Fortran compiler your're using in Windows XP?
/Raul
Marcus Lobbia February 5, 2004 19:23
If I remember correctly, Windows will only allow 2GB max for a single process... you may have to use Linux or a 64bit CPU/OS to exceed this limit (e.g., maybe try a Athlon 64 / Opteron running 64bit Linux, or a 64bit Sun/HP Unix workstation).
Mikel February 6, 2004 03:31
Compaq Fortran, 6.6b
Mikel February 6, 2004 03:33
Thanks Marcus. I am going to use Linux. It seems like the best short term solution.
Steve February 10, 2004 09:15
I had the same problem and I migrated on Linux !!
Steve
