-   -   to plot Mach contour using GNUPLOT (http://www.cfd-online.com/Forums/main/71337-plot-mach-contour-using-gnuplot.html)
killtimm December 26, 2009 10:50
I have a 2D unstructured mesh datafile which has the following format (for each cell, x1, x2 and x3 are different, so are with y values ):
x1 y1 Mach1
x2 y2 Mach2
#blank____________________________(for cell 1)
x3 y3 Mach3
x3 y3 Mach3
#blank
#blank
x1 y1 Mach1
x2 y2 Mach2
#blank____________________________(for cell 2)
x3 y3 Mach3
x3 y3 Mach3
#blank
#blank
...... ...... #for cell N
It's ok that a colored contour map could be made with pm3d
But I want to plot a contour with just black isolines like below:
http://em7jya.bay.livefilestore.com/...e/Ma_1part.jpg
Somebody may say that it can be realized using dgrid3d
But it will be impossible if the mesh is very large to consume
too much memory
Can anyone tell me how to plot the contour isolines like above?
It won't be better if commands are presented
Thanks in advance!
DoHander December 28, 2009 12:12
You can check Tecplot (if you have an academic license) - they have a lot of examples of how to plot these kind of data.
About Gnuplot - this is a good choice if you are a programmer, check the last version of Gnuplot, especially the demos directory - I'm sure you will found an example of isolines.
http://www.gnuplot.info/
http://sourceforge.net/projects/gnuplot/files/
Do
DoHander December 28, 2009 12:15
Here - some Gnuplot demos:
http://gnuplot.sourceforge.net/demo_4.2/
http://gnuplot.sourceforge.net/demo_4.2/contours.html
The last version is 4.4 probably you will find more demos.
