I cannot solve Pro. 6.5 in the Book by Patankar, |
February 11, 2004, 12:41 |
I am sorry to bother you all. Now I am reading the book " Numerical heat transfer and fluid flow" by Pro.Patankar, and sovle the problems following chapters. But it's difficulat to discretize it properly, onec I discretize it, it seems there is not enough boundary conditions to complete the " Simple" procedure. your help and advice will be appreciated.
Regards Ke |
February 12, 2004, 10:59 |
Re: I cannot solve Pro. 6.5 in the Book by Patanka
problem is stated well but it has a twist though. i have solved it earlier. here is a suggation. USE UPWIND SCHEME TO DISCRITIZE CONVECTIVE TERM AT POINT A. This will eliminate your point 1 for which you dont have the data.
February 12, 2004, 20:43 |
Thanks for your advice, I will try it.
Good weekend. |
February 13, 2004, 10:16 |
Problem 6.5 solved, thanks again
I sovled the problem 6.5 yesterday, using upwind method to avoid bothering the point beyond point 3. And I also lineaized the (uA)u term before the iterations were put into practice.
Thanks Good Day. |
Spectral Methods in Fluid Dynamics | Martin Bailon | Main CFD Forum | 3 | January 31, 2011 13:39 |
Linearized NS euqations: how to solve them?(problem with Matrix operations..) | matteoL | OpenFOAM Running, Solving & CFD | 0 | November 18, 2009 06:58 |
free on line compressible flow book | genick bar-meir | Main CFD Forum | 4 | December 5, 2005 00:25 |
free on line compressible flow book | genick bar-meir | Main CFD Forum | 0 | November 9, 2005 20:56 |
How to solve another continuum and momentum eqn? | west_wing | FLUENT | 0 | August 25, 2003 10:00 |
