January 27, 2010, 09:27 |
Phase choosing in Volume of Fluid Method
Gitesh
I am doinfg the simulation of buuble column. The air is coming from the bottom of the contener. Already stgnant water is 2/3 in the contener. So, Can anyone say me which is my secondary phase. I want to study of air-bubble motion. Please suggest me. With Regards, Gitesh. |
January 27, 2010, 11:54 |
phases
#2 | |
Liquid - primary phase
Air - Secondary Phase Quote:
CFDtoy |
January 28, 2010, 07:40 |
Gitesh
Thank you,
Can you say me about the surface tension in present case in detail. With regards, Gitesh. |
January 28, 2010, 10:57 |
surf tension
use value of 0.072. btw, this is important when the scales are pretty low ..curvature effects are dominant only at small scales..the values for the size you are looking can be off by 10-15% ..the difference one would notice with varying surface tension is the nature of liquid-air bubble interface..like increased or decreased interfacial corrugations ..
CFDtoy |
Errno 24 linux | ivanwhlau | OpenFOAM Running, Solving & CFD | 6 | July 1, 2009 10:16 |
interDyMFoam - change in volume fraction | gopala | OpenFOAM Running, Solving & CFD | 0 | April 27, 2009 10:46 |
fluid hot volume in fluid cold volume | zahid | FLUENT | 4 | June 1, 2002 09:11 |
help needed about phase change | Yanhu Guo | Main CFD Forum | 4 | January 23, 2001 23:16 |
