inflow-outflow conditions
Old   March 7, 2004, 17:09
Default inflow-outflow conditions
Chris Valade
I am trying to model, piston-driven, oscillatory flow in a channel that has one end open to the atmosphere. Ideally I would be able to specify a pressure at the outlet.
The problem is that the outlet becomes an inlet half way through each cycle and having an inlet with conditions set for an outlet causes a failure in the code.
It is possible to changes the conditions upon reversal but this results in errors in the results.
I have tried using a buffer layer but this did not work either.
Thanks for any advice.
outflow boundary conditions DaIN Main CFD Forum 4 May 12, 2011 14:32
Turbulent Inflow Conditions ali OpenFOAM Running, Solving & CFD 2 July 9, 2009 09:55
Correct location for inflow and outflow boundaries Varun CFX 1 May 23, 2008 03:43
Inflow without outflow! ANASTASIOS GEORGOULAS FLUENT 3 September 15, 2007 03:58
Outflow conditions causing ERROR #064 Coriolius Siemens 3 October 10, 2004 10:57
