March 4, 2010, 21:29 |
Viscous Flux Jacobian
Who has the experience computing viscous flux Jacobian for incompressible flow?
Suppose we set the primitive variables as [P, U, V, W]. I know hand calculating the convective flux Jacobian analytically is easy. But for viscous flux, the situation looks different. My own hand derivation shows that it should be zero for Cartesian grid. It may not be zero in the case of curvilinear grid. Am I correct? Thank you. |
March 9, 2010, 12:58 |
Rep Power: 18 |
The viscous flux Jacobians are not zero for a Cartesian grid.
March 9, 2010, 18:52 |
Thank you for your reply.
But are you sure? I mean incompressible flow with constant viscosity here. suppose in 2D case with kinematic viscosity as miu primitive variable: Q=[ P, U, V ], convective flux in X: E=[ U, U*U+P, UV ] viscous flux in X: Ev=[ 0, 2*miu*ddU/ddX, miu*(ddU/ddY+ddV/ddX) ] When I do the viscous flux Jacobian analytically: dd(Ev)/ddQ, all derivatives of Ev elements in terms of P,U or V get nothing. And someone also remind me the viscous terms are linear for incompressible N-S eq. Last edited by bearcat; March 9, 2010 at 20:23. |
March 9, 2010, 19:53 |
Rep Power: 18 |
I am assuming you are trying to develop an implicit algorithm. Since the viscous terms are linear, if you write Q(N+1) = Q(N) + DQ and substitute into the diff. eq., the terms containing the DQ can be carried to the left-hand side. The flux Jacobian (or the contribution to the system matrix) follow from that. In this case it will be mu multiplied by the coefficients of the difference terms.
March 9, 2010, 20:36 |
#5 | |
Yes, if we use a Jacobian-free Newton-Krylov method, your idea will be implemented easily. But I think if we can cancel it out analytically, then we don't have to compute it numerically and save some effort. The original 2D eq is: ddQ/ddt+dd(E-Ev)/ddX+dd(F-Fv)/ddY=0 (no source term) The 3x3 Jacobian matrix often acts as a coefficient in system matrix. My opinion is that all elements in viscous flux Jacobian matrix are zero if no coordinate transform is involved. |
March 9, 2010, 21:35 |
Rep Power: 18 |
You can ignore them, but the advantage of including them is that they contribute to the diagonal dominance of the coefficient matrix.
March 11, 2010, 00:40 |
This paper maybe is useful for you
peter. zhao
Rep Power: 16 |
For compressible flow, the below paper maybe is useful.
"Implicit multigrid solution of the compressible Navier-Stokes equations with application to distributed parallel processing", Tysinger, Thomas Lee, Ph.D. Thesis Cornell Univ., Ithaca, NY,1992. This paper introduced the viscous jacobian matrix for compressible NS equation. I think this method is also useful for your problem. |
March 11, 2010, 06:03 |
not zero
Rep Power: 17 |
[QUOTE=bearcat;249236]
viscous flux in X: Ev=[ 0, 2*miu*ddU/ddX, miu*(ddU/ddY+ddV/ddX) ] When I do the viscous flux Jacobian analytically: dd(Ev)/ddQ, all derivatives of Ev elements in terms of P,U or V get nothing. You get something. For example, dd(Ev)/ddU = [0, 2*miu*dd/ddX, miu*dd/ddY ] A discretized version would be dd(Ev)/ddU = [0, 2*miu*(1/Delta x), miu*(1/Delta y) ] gory |
March 11, 2010, 12:46 |
#9 | ||
viscous jacobian for compressible flow appears in many CFD books. But that's an easier and completely different case. For incompressible flow we don't have density as a primitive variable. [QUOTE=gory;249527] Quote:
March 11, 2010, 13:20 |
#10 |
Rep Power: 18 |
It's what you'll get if you follow the steps I outlined above - it results from the linear nature of the PDE and the linearization of the aforementioned viscous terms.
March 11, 2010, 17:14 |
Jacobians
#11 | |
Rep Power: 17 |
I don't know any reference. I agree with agd that you follow his instruction and you'll get it. Example: Consider a simple diffusion equation, ut = df/dx, where f = du/dx (d = \partial, i.e., one partial). Then, ut = A du/dx, where A=df/du=d(du/dx)/du=d/dx. It is an operator. If you're interested in the Jacobian (I'm not sure if you are) of the residual. It's related but a bit different, I think. I guess it goes like this: A discretized version of df/dx may be RHS(j) =(u_{j+1} - 2 u_j + u_{j-1})/(Delta x)^2, where RHSis a residual vector and RHS(j) is the j-th component. The Jacobian is a matrix defined as dRHS/dU where U = [u1, u2, u_{j-1}, u_j, ...], i.e., the discrete values. So, for example, (dRHS/U)(j,j) = dRHS(j)/du_j = -2 / (Delta x)^2 (dRHS/U)(j,j-1) = dRHS(j)/du_{j-1}= 1/(Delta x)^2 and so on. In any case, the Jacobian is not zero for viscous terms, I think. gory |
Jacobian Matrix of Van Leer Flux Splitting Vector | Jackson | Main CFD Forum | 2 | July 29, 2010 10:57 |
Flux Jacobian for flux splitting | mecheng1600 | Main CFD Forum | 0 | December 5, 2009 20:07 |
viscous flux treatment in compressible NS sovler | JG | Main CFD Forum | 2 | January 9, 2008 15:29 |
Jacobian Coefficient matrices for the viscous flux | Andy | Main CFD Forum | 8 | February 25, 2004 23:53 |
Jacobian Coefficient matrices for the viscous flux | Andy | Main CFD Forum | 0 | February 19, 2004 13:59 |
