June 12, 2009, 14:38 |
Fluent Source Code
Rep Power: 16 |
Is it possible to auto-generate the source code for a Fluent simulation done interactively on the GUI? Thanks. |
June 13, 2009, 12:45 |
Think again about how you phrased that question
Charles
Rep Power: 18 |
I think what you are asking is "Can you record a script file of the problem setup", and the answer to that is yes, you can record a journal file. RTFM, it is explained there.
June 15, 2009, 05:30 |
Rephrasing my question
Rep Power: 16 |
Perhaps my question wasn't phrased clearly enough...no, I wasn't referring to the script file, but to the source code or the programme file in C language that Fluent (and also Gambit) uses to run the simulation process - from the discretization to the boundary condition and material properties setup to the solution process etc... For example, in COMSOL and the MATLAB curve fitting tool, you can generate the m-file (MATLAB source code) that is used to run that particular process. I know we can couple our own UDFs to Fluent, but are we able to see what goes on "behind the scenes" in Fluent itself? Thanks!
June 15, 2009, 05:34 |
You must be joking!
Charles
Rep Power: 18 |
Nope, and if, unlike most of us, you bothered to read the license agreement you would probably find a paragraph explicitly prohibiting the "uncompiling" or any other form of reverse-engineering of the code.
March 3, 2010, 06:41 |
Dr Suvash C Saha
Rep Power: 16 |
That's why FLUENT called the BLACK BOX...
March 3, 2010, 20:34 |
N/A
Rep Power: 17 |
Fluent is a proprietary software. If you look into opensource codes like OepnFOAM, Elmer etc. , you will have an idea of how things are done in Fluent.
Display Modes | |
Source Terms in Momentum Balance | vidyaraja | Main CFD Forum | 0 | May 25, 2009 15:24 |
Source Terms in momentum Balance | vidyaraja | FLUENT | 0 | May 25, 2009 13:16 |
search for a code to R/W fluent case/data file | zou jianfeng | FLUENT | 0 | November 11, 2008 08:16 |
Pre & Post-Processor source code !! | C. Beghein | Main CFD Forum | 1 | January 30, 2002 08:35 |
Source term for diffusion equation in FLUENT 4.5 | Raja Banerjee | FLUENT | 1 | August 30, 2000 23:00 |
