-   -   Centrifugal Pump Impeller design (http://www.cfd-online.com/Forums/main/73176-centrifugal-pump-impeller-design.html)
invincible328 March 1, 2010 12:15
Hello friends,
I am a Master's student at University of Cincinnati. My thesis is about Study of Two-phase flows in Centrifugal pump impellers and I am new to CFD. Can anyone please help me out with how to design and mesh an impeller in Gridgen, or can you suggest some tutorials which will be useful in doing so? Tutorials in Solidworks or any other software is also fine. I just want to know the procedure of creating an impeller.
Thanks.
rmatus March 1, 2010 20:54
There's a script for that.
Rajiv:
You might try the Kreila import script on Pointwise's Glyph Script Exchange. It reads profile curves for hub, shroud, and blade geometries for impellers and creates Gridgen database entities for them.
Hope this helps,
Rick
invincible328 March 2, 2010 14:48
Thanks Rick. I will let you know if I run into any trouble. Thanks once again for helping me. :):):)
Jade M April 30, 2010 14:18
What software are you going to be using?
invincible328 April 30, 2010 14:30
I want to use Fluent. Another possibility that I am looking at is OpenFOAM. I just started learning OpenFOAM and I am not sure yet as to how it handles Turbomachinery.
Jade M April 30, 2010 14:33
I see. I am very experienced in CFD and have gotten reasonably up to speed with CFX. I am getting ready to treat a centrifugal pump problem in CFX. I was hoping that we could help each other but unfortunately I am not familiar with FLUENT or OpenFoam. Good luck with your analysis.
invincible328 April 30, 2010 14:38
Well, one of my lab mates is using CFX and he has done some work on inducer of a centrifugal pump. I have not looked at CFX, so I cannot say anything about it.
I will try to look at that and if I find it easy to learn and use, I will use it. Anyways, keep in touch so that we can share some more information and good luck to you too!!!!!
Jade M April 30, 2010 15:31
Thanks!
If you're deciding between CFX and FLUENT, I understand that CFX is far more user-friendly and fully integrated into Workbench. However, I do not know which one is better for turbomachinery. I would think that CFX would be just fine and the user-friendliness would put me over the fence. I actually just recently evaluated the two and made a recommendation to my company as to which software to purchase, and CFX won out. ANSYS has a Capability Chart which compares the CFX and FLUENT which may be of interest to you.
yvonne July 9, 2010 11:11
Hi all,
Ive been working on pump geometry for the past year, and there is a balanced opinion of preference of FLUENT over CFX and vice versa.
OpenFOAM mite give some problems with rotating domain (version 11 too)
I am rite now starting work on centrifugal impeller. I am using GAMBIT. Can you please tell me if its a suitable software or is there anything better available???
hasan adel October 17, 2011 11:59
please help me
please anyone have videos or pdf theses for this model to learn from it:confused:
Far October 17, 2011 12:39
you can mesh with gambit and gridgen easily. If needed I can show you method on my computer with the help of skype.
kkiitm October 28, 2011 03:03
centrifugal pump impeller
2 Attachment(s)
I have developed unstructured mesh to the centrifugal impeller and I am using CFX solver for it.
do u recommend structured grid for impeller? is it difficult to develope hexa mesh in icemcfd- I tried blocking the impeller but I found very difficult.
please suggest me
Attachment 9784Attachment 9785
I tried a trail please see what went wrong in it
Far October 28, 2011 03:29
Although it is not necessary to use the full structured grid for the turbomachinery or any other type of flows. But for turbomachinery flows, structured grid is used for the following reasons
1. It is custom in turbomachinery field to use the structured gird
2. due to flow alignment, the number of nodes can be reduced in the particualr direction
3. In turbomachinery flows, boundary layer is very much important, so you may create a layer of 10-20 cells around blade with structured elements (o-grid) and rest of the domain may be meshed with unstructured elemetns.
4. Keeping in view point 3 above, you can control the Yplus with structured mesh in the vicinity of no slip walls
I strongly recomend the structured gird and I think it is not very much difficult. Moreover it is worth to spend some time on high quality meshing than having low confidence in the final results.
Far October 28, 2011 03:30
pls also attach the pic of convergence plot
kkiitm October 29, 2011 02:23
convergence
1 Attachment(s)
Mr.
You have provided useful information, on structured grid
I am using ICEM-cfd for the meshing. to create o-grid for the complete impeller is the only method. or any method that I could not find can you please suggest some tutorial. please.
I have attached the convergence plot to it. please give suggestions..
kkiitm November 1, 2011 04:28
Suggestions plz
HELLO:confused:
Far November 1, 2011 15:30
1. which turbulence model you are using.
2. If you want to mesh in ICEM, I think you must go through blade pipe and wing body tutorial first. Creating mesh for centrifugal compressor is bit tricky. Here are some steps you should follow.
a) make the geometry (or create part ) for periodic, casing (enclosed by periodic surfaces), hub (same as shroud), inlet and outlet
b) then create block and split them in such a way so that we can associate to periodic, casing, hub, blade , inlet and outlet
c) dont forget to project mesh on surfaces
Far November 1, 2011 15:34
In my opinion you must try for the residual values at least 1e-6 for continuity, momentum, energy and turbulence quantities.
Graham81 November 3, 2011 05:01
1) What is your time step setting?
2) What happens if you continue the run for another say 2-3 hundred
iterations?
PSYMN November 3, 2011 10:11
TurboGrid
I would recommend CFX as the solver with blade modeler for the geometry creation and TurboGrid for the meshing.
CFX is well known to be the leader in turbo machinary.
And while ICEM CFD is a good flexible tool that can be used for turbo machinery, TurboGrid was designed for it. It is automated and features excellent smoothing. You will also find more applicable tutorials for TurboGrid.
These are all in Workbench which has its own benefits, including the ability to to a parametric and persistent optimization (if you wanted to head that way).
Best regards,
Simon
