[Sponsors] | |||||
sateesh
Rep Power: 5 ![]() |
Dear Sir,
I am using FLUENT to capture the flow pattern in a irregular 3-D geometry under turbulence and non-isothermal condition. I am getting the statement like this " reversed flow in 20 faces on pressure-outlet 6" and "turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 86657 cells" . Finally solution is not converging can you suggest me how can i rectify the problem Thanks in Advance With Best Wishes & Warm Regards Sateesh |
E Busquets
Rep Power: 0 ![]() |
I do not have a lot of experience; however, from what I know the issue with the second error refers to a poor mesh. In my experience these errors occur when utilizing turbulent flow and they appear just in the beginning of the analysis. Then, as the number of cells decreases, they disappear. If the number of cells is increasing instead of decreasing, I would go back and check my mesh and the time step that is being used. Regards |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| reversed flow during RNG in turbulence-k epsilon | Suman Kandula | FLUENT | 4 | April 2, 2012 07:12 |
| Reversed flow...>>>Please HELP...! | sushii | FLUENT | 14 | October 29, 2007 05:27 |
| reversed flow | free | FLUENT | 3 | August 10, 2007 14:39 |
| reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 13:11 |
| reversed flow | Sastry | FLUENT | 5 | March 22, 2007 09:05 |
