-   -   errors (http://www.cfd-online.com/Forums/main/7328-errors.html)
Fahad March 23, 2004 14:20
errors
Hello! i m trying to run a programme in flexpde but its giving an error "memory protection fault" can any body help i m using flexpde 2.20e on windows xphome.
here is the code :if there is an error in the code plz let me know many thanx Fahad
---------------------------------------------------- TITLE 'Test FIR'
COORDINATES
CARTESIAN3
EXTRUSION
SURFACE "BOTTOM" Z=0
LAYER "GaAs WAFER"
surface "metal" z=100e-9
layer "metal"
SURFACE "2DEG" Z=101e-9
LAYER "GaAs"
SURFACE "AlGaAs " Z=111e-9
LAYER "AlGaAs"
SURFACE "nAlGaAs " Z=141e-9
LAYER " nAlGaAs "
SURFACE "GaAs Top" Z=171e-9
LAYER "GaAs Top"
SURFACE "ELECTRODES TOP " Z=181e-9
LAYER "ELECTRODES"
SURFACE "TOP" Z=191e-9
SELECT
VARIABLES V
DEFINITIONS
KGaAs=13
KAlGaAs=12.90
Kmetal =1e4
Kair=1
knAlGaAs=13.23
K=Kair
kelectrodes=kair Eps0=8.54E-12
cond
Vgate=-45e-3 Velectrodes=0 d=1e-6
Ex= -dx(v) Ey= -dy(v) E= -grad(v) Em= magnitude(E)
Jx= cond*Ex Jy= cond*Ey J= cond*E Jm= magnitude(j) eqn= div( -cond*grad(v))
INITIAL VALUES EQUATIONS
DIV(K*Eps0*GRAD(V))=0
CONSTRAINTS BOUNDARIES
REGION 1 "chip BASE"
LAYER "GaAs WAFER" K=KGaAs cond=0
layer "metal" k=kmetal cond=5.99e7
LAYER "GaAs" K=KGaAs cond=6.4e-4
LAYER "AlGaAs" K=KAlGaAs cond=0
LAYER " nAlGaAs " k=knAlGaAs cond=0
LAYER "ELECTRODES" K=kair cond=0
START (-2.5e-6,-0.5e-6) LINE TO (2.5e-6,-0.5e-6) LINE TO (2.5e-6,0.5e-6) LINE TO(-2.5e-6,0.5e-6) TO FINISH
REGION 2 "metalstrip"
START (-0.95e-6,-0.47e-6) line to (-0.95e-6,0.47e-6) to (0.95e-6,0.47e-6) to (0.95e-6,-0.47e-6) to finish
REGION 3 "SET"
LAYER "ELECTRODES" K=KMETAL VALUE(V)=0 cond=3.7e7
START (0.25e-6,0)
ARC(CENTER =0,0) ANGLE=360 TO FINISH
REGION 4 "GATE1"
LAYER "GaAs WAFER" K=kGaAs cond=0
LAYER "ELECTRODES" K=kMETAL value(v)=-25e-03 cond=3.7e7 START (1.0e-6,0.5e-6) LINE TO (1.1e-6,0.5e-6) LINE TO (1.1e-6,0.35e-6) LINE TO (1.4e-6,0.5e-6) LINE TO (1.4e-6,0.5e-6)
LINE TO (1.1e-6,0.27e-6) LINE TO (1.1e-6,0.26e-6) LINE TO (1.0e-6,0.26e-6) TO FINISH
REGION 5 "GATE2"
LAYER "ELECTRODES" K=kMETAL value(v)=-25e-03 cond=3.7e7 START (1.0e-6,-0.5e-6) LINE TO (1.1e-6,-0.5e-6) LINE TO (1.1e-6,-0.35e-6) LINE TO (1.5e-6,-0.5e-6) LINE TO (1.5e-6,-0.5e-6)
LINE TO (1.1e-6,-0.39e-6) LINE TO (1.1e-6,-0.35e-6) LINE TO (1.0e-6,-0.35e-6) TO FINISH
REGION 6 "GATE 3"
LAYER "ELECTRODES" K=KMETAL value(v)=-50e-03 cond=3.7e7
START (-1.0e-6,0.4e-6) LINE TO (-1.1e-6,0.4e-6) LINE TO (-1.1e-6,0.15e-6) LINE TO (-2.5e-6,0.15e-6) LINE TO (-2.5e-6,-0.15e-6)
LINE TO (-1.1e-6,-0.15e-6) LINE TO (-1.1e-6,-0.4e-6) LINE TO (-1.0e-6,-0.4e-6) TO FINISH
REGION 7 "DRAIN"
LAYER "ELECTRODES" K=Kmetal value(v)=0 cond=3.7e7
START (0.25e-6,0) LINE TO (0.35e-6,0) line to (0.35e-6,-0.5e-6) LINE TO (0.25e-6,-0.5e-6) TO FINISH
REGION 8 "source"
START (-0.25*d,0) LINE TO (-0.35e-6,0) line to (-0.35e-6,-0.5e-6) line to (-0.25e-6,-0.5e-6) to finish
PLOTS
grid(x,y,z)
CONTOUR (V) ON SURFACE Z=101e-9
end
