how to generate an annulus with inner pipe rotate?
Old   March 27, 2004, 18:46
Default how to generate an annulus with inner pipe rotate?
a person need help
Hello, Gurus,
I am a new user of GAMBIT and FLUENT, i am working a small project on annular flow, now i have a problem, i generated a 3D annulus (half part)and meshed, and then run with FLUENT, but sinceit is a 3D problem, I have no idea how to examine the annular velocity distribution, and also, i am not sure of my procedure, and mesh method, is there anyone has an example or tutorial,or existiong one that i can have a look? thank you very much!!
also, if the inner pipe is rotating, then what shall i do different from the previous one?
[blockMesh] generate a graded pipe mesh. jenright OpenFOAM Meshing & Mesh Conversion 0 August 22, 2009 08:58
Problem with Eccentric pipe annulus..Pls Help me Parag Ramteke FLUENT 2 April 4, 2005 06:34
how to generate an annulus with inner pipe rotate? a person need help FLUENT 0 March 27, 2004 18:48
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
