Fully Expanded Jet Mach Number.
Old   June 28, 2010, 11:40
Default Fully Expanded Jet Mach Number.
oe
oe_jet is on a distinguished road
Hi everyone,
I am running an Euler simulation for an underexpanded jet. The design Mach number is Md = 2.2, and this jet operates at a pressure ratio (p at jet exit to ambient p) = 1.2.
The fully expanded jet Mach number is
Mj = sqrt ((2/gamma-1)((P0/Pe)^((gamma-1)/gamma) -1)),
where P0 is the Chamber Pressure, gamma=1.4, Pe =14.7 psi (freestream).
Mj = 2.3166 for PR=1.2 by the above formula, but in the simulations the flow Mach number goes up to 3.2 in the first shock.
Could anyone please give some insight. Why the Mach number in the simulation is same as the Mj value by the formula.
Thank you.
oe_jet is offline   Reply With Quote
The Far-field Pressure Boundary & Low Mach Number Saif-Deen Akanni FLUENT 1 March 5, 2007 05:05
How to find Mach Number Tobias FLUENT 2 October 18, 2005 09:59
Mach number and flow compressibility Guosheng Kang Main CFD Forum 5 October 26, 1999 15:56
TVD scheme at low Mach number Axel Rohde Main CFD Forum 5 August 6, 1999 02:01
how calculate the density in low mach number? Juhee Lee Main CFD Forum 1 July 31, 1999 15:26
