Axial compressor bleed modelling
Can anybody tell me how to modelling bleed massflow in a multistage axial flow compressor blade row using Ansys CFX. The model is a mutli stage compressor with bleed in a rear stator blade row . There was no option to specify the bleed region using Turbogrid (pre processor) or model it in the CFX-pre. I dont want to specify the entire shroud above the blade row as an outlet. I wanted to define a small area in the shroud as hole for bleed. :confused: Thanks, Kishore |
Hi Kishore,
Did you find an answer for your question?? Actually I am trying to simulate the same problem that you mentioned here and I do not know how to do it. It would be great if I can get some help, Thanks, ZIZO |
