March 12, 2010, 05:14 |
Axial compressor bleed modelling
Kishore Kumar C
Can anybody tell me how to modelling bleed massflow in a multistage axial flow compressor blade row using Ansys CFX. The model is a mutli stage compressor with bleed in a rear stator blade row . There was no option to specify the bleed region using Turbogrid (pre processor) or model it in the CFX-pre. I dont want to specify the entire shroud above the blade row as an outlet. I wanted to define a small area in the shroud as hole for bleed. Thanks, Kishore |
May 28, 2014, 20:00 |
Gamil
Hi Kishore,
Did you find an answer for your question?? Actually I am trying to simulate the same problem that you mentioned here and I do not know how to do it. It would be great if I can get some help, Thanks, ZIZO |
axial compressor, bleed, cfx, multistage |
Modelling Axial Flow Fans | buzzybee | Main CFD Forum | 1 | July 29, 2009 09:45 |
Surface streamlines on axial flow fans | Jennifer | CFX | 2 | February 17, 2009 14:50 |
Advice on multi-phase flow modelling | Martin | Main CFD Forum | 3 | October 14, 2008 05:16 |
Examples of axial fan modelling | Jenny | FLUENT | 1 | November 30, 2006 12:25 |
Computational Modelling of Vortex Separators | May Lim | Main CFD Forum | 6 | November 13, 1998 12:36 |
