Loading MRI data in Gambit
Does anyone knows how to import MRI data into Gambit?
What exactly is the format of the file you want to import in gambit and what you intend to do with it ?
I mean your data file hoes some grid structure ? Do |
Hi, i am actually using CMRtools to analyse the data from MRI images of a heart. i need to import the data from CMRtools into Gambit but totally have no idea how to go about doing it. I need to mesh the heart using gambit
In Gambit you need a geometrical model of your heart (this can be drawn directly in Gambit or imported from an external CAD package). If your software can generate iges or stl geometries, then you can import this in Gambit. After that you will be able to mesh the heart.
Do |
Hi i have successfully imported the shape of the heart into gambit using import vertex data. Do i need to connect all the points as the image consist of 100 over points
gambit_fortran
hi,
does any one know how to convert the mesh from gambit into fortran. thank a lot for your help.. |
