February 25, 2016, 19:01 |
Question about residual in S-A model
Hanxun Yao
Rep Power: 10 |
I am recently validating my S-A turbulence model by using a plat plate case, but odd thing happened when I was running higher order spatial scheme (2th and 5th order) of inviscid term. The residual was oscillating around 1e-1 and did not converged at all. In order to exclude the mesh problem, I redid a very simple mesh with just a viscous wall beside without round leading edge, while same thing happened. Afterwards, to let the case simper, I repeated my simulation with just inviscid solver, unfortunately, still diverged, which confused me a lot. Could someone please give a suggestion? what would causes the problem? really appreciated your help. PS: my case run as below: initial condition: mach number =0.2 (since compressible solver) inlet velocity =5.4 (m/s) inflow turbulent eddy viscosity_tilde =3.0e-5/1.2 density =1.2 temperature,pressure and energy initiated as routine method. numerical method: 5th order spatial discretization for inviscid flux 2th order spatial discretization for viscous and diffusive flux 2th order time discretization (RK SSPRK method) CFL number 0.1 (been decreased from 0.5 when running high order scheme) |
Display Modes | |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
settlingFoam unstable? | bendel_boy | OpenFOAM Running, Solving & CFD | 38 | July 8, 2016 05:07 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Why RNGkepsilon model gives floating error | shipman | OpenFOAM Running, Solving & CFD | 3 | September 7, 2013 08:00 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
