John C. Chien
July 28, 1998 18:47 |
Re: Supersonic fluid flow patern in a dip
The formal subject name maybe :" Supersonic Flow over a Cavity ". The flow inside the cavity normally is subsonic. If this is the case. Then try the AIAA Journal. Supersonic flow over a cavity is usually un-steady, which is created by the shear layer/ supersonic flow interaction. A shot in this case does not give you the whole picture. (If this is not the case, I would like to know how you create supersonic flow in a cavity.)
