Intel Fortran (ifort 8) and MPICH
I would like to know if somebody have used the MPICH implementation with the Intel's Fortran 90 compiler for Linux or the Lahey's Fortran 90 for Windows.
I have a problem using both compilers under a Fortran 90 source code. The compiler does not recognize the mpi module or library. Thanks in advance. |
Re: Intel Fortran (ifort 8) and MPICH
You probably want to test the MPICH installation by compiling its test programs and running them with different "-np *". If this works, you can then start thinking of using MPI in your own code.
Thank you for the answer.
The first thing I tried, was to compile the examples that come with MPICH. But the fortran 90 ones fail to compile with the cited compilers. Goicox |
Before you install the MPICH, you may have to set some environments first. Such as:
setenv FC f90 setenv F90 f90 configure good luck! |
There is NO problem for Intel Compiler 8.0 + MPICH + Linux. I have tried it.
