Intel Fortran (ifort 8) and MPICH
Old   April 11, 2004, 12:00
Default Intel Fortran (ifort 8) and MPICH
Goicox
I would like to know if somebody have used the MPICH implementation with the Intel's Fortran 90 compiler for Linux or the Lahey's Fortran 90 for Windows.
I have a problem using both compilers under a Fortran 90 source code. The compiler does not recognize the mpi module or library.
Thanks in advance.
Old   April 11, 2004, 15:35
Default Re: Intel Fortran (ifort 8) and MPICH
noName
You probably want to test the MPICH installation by compiling its test programs and running them with different "-np *". If this works, you can then start thinking of using MPI in your own code.
Old   April 11, 2004, 20:54
Goicox
Thank you for the answer.
The first thing I tried, was to compile the examples that come with MPICH.
But the fortran 90 ones fail to compile with the cited compilers.
Goicox
Old   April 13, 2004, 04:42
Linfeng
Before you install the MPICH, you may have to set some environments first. Such as:
setenv FC f90
setenv F90 f90
configure
good luck!
Old   April 28, 2004, 00:59
Zeng
There is NO problem for Intel Compiler 8.0 + MPICH + Linux. I have tried it.
intel quad core with ANSYS CFX-v11.0 (without SP1) Rogerio Fernandes Brito CFX 12 May 30, 2008 02:59
distributed mpich problem Trevor CFX 15 January 9, 2007 17:08
MPICH for Windows (Fortran) jojo Main CFD Forum 4 May 3, 2005 09:10
MPICH problem (CFX-5.7.1) Jesper CFX 7 April 16, 2005 05:04
MPICH : undefined reference to.. Vincent Siemens 3 March 24, 2005 12:30
