March 25, 2010, 07:05 |
CFD vs Experimetal Results for Aerofoil
owhelan
Hi, I'm comparing experimental results obtained for a NACA 0012 aerofoil in a wind tunnel with CFD results ran on Fluent.
The CFD model was a very simple 2D, steady time, incompressible model using k-epsilon and standard wall functions. BC's were a pressure inlet and outlet and symmetry on upper/lower surfaces or fluid domain. Despite the low inlet gauge pressure of 215pa, I'm getting pressure readings on the surface of the aerofoil that lead to pressure coefficients greater than +ve 1 on the pressure surface at 9 deg and 12 deg incidence. Can anyone explain why this may be happening? Is it a problem with the wall function? Thanks Osh |
March 25, 2010, 09:12 |
Karatix
What CFD Package and mesh generator do you use?
March 25, 2010, 09:15 |
owhelan
I an using GAMBIT to generate the mesh and FLUENT to run the simulation.
March 25, 2010, 10:54 |
Karatix
Unfortuntately I am not using Gambit and Fluent anymore and cannot remember whether I had similar problems. I think I used a structured grid without a wall function. The turbulence model was Spalart Allmares and worked pretty well.
Have you got subsonic, transonic or supersonic flow? Does it have a great difference between the value and +1? |
Comparison of experimental and CFD results for the VA-2 supercritical airfoil | Aurélien | FLUENT | 3 | Today 10:39 |
CFD vs Experimetal Results for Aerofoil | owhelan | FLUENT | 0 | March 25, 2010 07:03 |
DOES ASPECT RATIO PLAY A PART IN CFD RESULTS? | RIF | Main CFD Forum | 2 | January 5, 2008 13:14 |
ASME CFD Symposium | Chris Kleijn | Main CFD Forum | 0 | August 22, 2001 06:41 |
Can we quantify the fruits of CFD? | Brady Brown | Main CFD Forum | 14 | December 15, 1999 09:42 |
