overlap cells
Old   April 15, 2004, 04:25
Default overlap cells
CAgner
I have a problem in STAR-CD 3.15. I´ve refined a mesh and if I now make the centroid check there is the following error: centroidal check failed, cells overlap. What can I do now to avoid this error. Thanks for your help.
Old   April 15, 2004, 08:29
Default Re: overlap cells
Help
I can think of four options, Use another code Don't refine your grid Don't do a centroid check Post this message at the Star forum
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
physical boundary error!! kris Siemens 2 August 3, 2005 00:32
