-   -   Parallel Fortran (http://www.cfd-online.com/Forums/main/74550-parallel-fortran.html)
ho_afshar April 3, 2010 03:05
Parallel Fortran
Hi every body.
I'm working on a cfd code in fortran. Run times take several days so I need to run my code in parallel mode. As I have not used parallel commands, is there any way to run it on multiple Cpus.
Thanks.
Hossein.
Ho_afshar@yahoo.com
aladdincham April 3, 2010 03:40
you can read the user manual of fortran,it will tell you what do you want to know!
ho_afshar April 3, 2010 03:56
Thanks,
You mean that it's possible to run a serial program on multiple cpus in all versions of fortran?
I will be thankful if you send me the related documents.
ho_afhar@yahoo.com...
(ho_afshar)
Regards.
quarkz April 3, 2010 07:49
to run your code in parallel, u 'll 've to modify the code ie add some commands in your code to instruct how to run it in parallel. u can use openmp, which seems to be easier, or mpi, which seems more flexible.
DoHander April 3, 2010 13:57
You need to re-write your code to be able to run this in parallel. You need to specifically develop a parallel version of your code.
Search some tutorials (on Google) about OpenMp and MPI to clarify your ideas about parallel programming. My recommendation is to use OpenMP if you have a multiprocessor machine and MPI if you have a cluster made by a few computers.
Do
ho_afshar April 4, 2010 02:04
Do
Dear Do,
Thank you very much for your comment.
I had heard that some versions of fortran are capable to handle a serial program on multiple cpus. The one who told me about that is not available now. So I asked if someone else has done so.
Cheers.
Hossein
quarkz April 4, 2010 10:31
Well, u are partly right in saying that. intel fortran has an auto parallel option to enable openmp on some loops. however, u need to make sure it won't cause any error.
ho_afshar April 4, 2010 12:52
Ok. Thanks.
I need that in Compaq Visual Fortran 6.
Whould you explain more how I can use this parallel option.
Thanks.
DoHander April 6, 2010 11:20
I'm sorry to inform you but Compaq Visual Fortran does not have an auto parallel option and it is a quite old Fortran compiler.
If you want a new, modern, Fortran compiler try Intel Fortran (commercial) or gfortran (free alternative).
Please try to understand that what you want a compiler that will magically transform your serial code to a parallel code does not exist (at least not after my knowledge). You have two alternatives:
1. OpenMP - this will allow you to parallelize your code in a relative simple way (work on multiprocessors machines), check this link for a short introduction and a few examples:
http://en.wikipedia.org/wiki/OpenMP
2. MPI - true parallel codes, this will run on multiple computers at once (a cluster). More complicated then 1.
Don't waist your time searching for a silver bullet and take some time and read about parallel programming, you will have a much clear idea about what you can use.
Do
ho_afshar April 7, 2010 07:47
Do
Thank you very much for your helpful comments.
Cheers
