-   -   centrifugal pump (http://www.cfd-online.com/Forums/main/7462-centrifugal-pump.html)
john April 23, 2004 07:17
centrifugal pump
where can I get tips to improve efficiency of centrifugal pump?
Thanks
BeachComber April 23, 2004 15:54
Re: centrifugal pump
That is such a general question - you probably will not get much help. For example: are you referring to design point or off-design efficiency; how bad is it to begin with; what problems does the pump have now; is cavitation a problem now; are you overloading the blades now; how good or bad is the manufacturing of the components (castings or machining), etc.
