May 13, 2009, 15:30 |
Flat plate transition
Rep Power: 17 |
I'm trying to simulate the transition on a flat plate using an extremely fine mesh and a high order DNS. I wonder what boundary conditions I need to impose in order to obtain transition. Because on a flat plate without a pressure gradient I suppose the only factors that can trigger transition will be the free stream turbulence and the surface roughness. I don't plan to include the surface roughness into this simulation so i suppose if I don't somehow include some fluctuations in the boundary condition I will never be able to catch the transition. How will be best to include these fluctuations ? I was thinking at adding some random noise (or to use a step function at each time step) to alter the speed in the chordwise direction. Thanks. |
May 17, 2009, 05:33 |
Edison
Rep Power: 17 |
I think you may read the papers by Fasel about how to generate disturbance to produce transition.
May 19, 2009, 10:42 |
Rep Power: 17 |
This is the article ?
"Spatial direct numerical simulation of transition phenomena in supersonic flat plate boundary layers" If not, can you please send me the title of Fasel paper. Thanks. |
May 20, 2009, 11:46 |
Rep Power: 17 |
The following papers might be of help, although some of them are for bypass transition...
http://www.liv.ac.uk/~em22/papers/GT-2002-30238.pdf http://www.liv.ac.uk/~em22/papers/96-GT-444.pdf http://www.liv.ac.uk/~em22/papers/origins_of_spots.pdf |
May 20, 2009, 12:47 |
Rep Power: 17 |
Thanks SSK
April 8, 2010, 02:07 |
Rep Power: 17 |
Dear SSK
Your lins are very useful. I'm working on transition modeling in flat plate too. I need details of some experimental data. Would you help me how can i found them? ghazanfar.zahedi@gmail.com Thanks alot for your favor Ghazanfar Zahedi |
Display Modes | |
Flat Plate Transition Test Case | Adam | CFX | 1 | June 24, 2005 00:12 |
Boundary layer transition over a flat plate | shraman | Main CFD Forum | 1 | May 12, 2005 05:55 |
flat plate transition: SST k-omega divergence | Peter Gasparovic | FLUENT | 4 | May 3, 2005 14:54 |
'Fluent for Flat Plate Oscillatory BL Transition | Jay | FLUENT | 11 | July 11, 2002 06:48 |
2D Flat Plate Oscillatory BL Transition | Jayd | Main CFD Forum | 2 | June 18, 2002 09:02 |
