April 28, 2004, 07:26 |
Pressure-based mutiblock method
I'm trying to solve with the pressure-based composite grid method for Navier-Stokes equations some multiconnected cases as the channel with two baffles simulated by Wright and Shyy. I'm using a Neumann internal boundary condition for the pressure correction map. In order to avoid the pressure jumps that appair in some interfaces, Wright and Shyy suggest to force the normal momentum balance between each control volume of this interfaces. We have donne it but it doesn't works. Have I understood correctly what Wright and Shyy suggest??? Is there other ways to avoid this pressure jumps in multiconnected grids??? |
Display Modes | |
What is C.V. based finite element method | C-H Kuo | Main CFD Forum | 4 | September 19, 2022 15:06 |
Using Density Gradient C_R_G(c,t), Pressure Based Solver | Anirudh_Deodhar | Fluent UDF and Scheme Programming | 1 | October 25, 2013 06:43 |
Setup/monitor points of pressure and force coefficients | siw | CFX | 3 | October 22, 2010 07:07 |
Pressure Rise Error | emueller | CFX | 0 | May 5, 2009 12:08 |
Pressure Possion equ.and multigrid method | Tony | Main CFD Forum | 16 | April 28, 2001 13:08 |
