April 9, 2010, 19:12 |
Turbulent viscosity
Santhosh
Rep Power: 16 |
What exactly is the turbulent viscosity in a physical sense? How is it related to the velocity, like local velocity, resultant velocity?
How does it affect heat transfer? |
April 10, 2010, 00:40 |
Hamid Zoka
Rep Power: 18 |
Dear San.Pirate
when flow is laminar, diffusion mechanism within the flow is only performed by molecular motions.viscosity,as a dissufion coefficient, is the parameter to quantify this phenomenon. But when the flow becomes turbulent, diffusion mechanism is not only performed by molecular motions, but also it is going to be highly intensified by eddies motions. therefore when modeling the turbulence using eddy viscosity models, we need to intensify diffusion coefficient by adding turbulent viscosity to the molecular one. this coefficient will be applied to both momentum and heat transfer equations. does it help? regards |
April 10, 2010, 18:41 |
Santhosh
Rep Power: 16 |
Thanks for the reply,
I understand the need to use it in the eddy viscosity models. And the reason that the eddies formed during turbulence increases its value. But how does the magnitude of turbulent viscosity affect the heat transfer and velocity in a vague physical sense? (For the sake of understanding) Just like flow friction causes the viscosity, and thereby increase the shear rate, what is the role of turb. viscosity. |
April 12, 2010, 00:29 |
Hamid Zoka
Rep Power: 18 |
Dear San.Pirate
as i told you before, this term is added to molecular viscosity in momentum and energy equations and intenify diffusion mechanism in these equations. therefore turbulent viscosity increases the shear rate and affect the velocity and heat transfer. turbulent viscosity is not a physical concept. it is a virtual viscosity. it is a just a model to predict turbulent flow characteristics. does it help? regards |
April 12, 2010, 00:37 |
Santhosh
Rep Power: 16 |
Yes, thanks alot..
physics, turbulence, viscosity |
Display Modes | |
reversed flow at pressure inlet and turbulent viscosity is limited.... | cfdiscool | FLUENT | 10 | June 10, 2015 07:15 |
Link between eddy viscosity and subgrid-scale turbulent viscosity in LES | Marvin | Main CFD Forum | 6 | December 4, 2009 12:08 |
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel | nuimlabib | Main CFD Forum | 0 | August 4, 2009 01:05 |
effective? turbulent? laminar? viscosity | MIssNancy | FLUENT | 3 | December 3, 2002 00:53 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 07:13 |
