initial and boundary conditions for flapping hovering flight
I'm thinking of doing some simulations of hovering flight. in the past, i've been doing simulations of flapping flight. i simply set u=1,v=0 as the initial condition for the entire domain. the boundary condition is u=1 at the left boundary, indicating inflow. outflow at the right uses convective boundary condition. du/dy=0 for the top/bottom boundary. however, how should the boundary and initial conditions since it's hovering. hence, u/=1. pls help. tks! |
As the name suggests -- hovering flight -- there is no forward motion, you can use initial conditions u = v = 0 everywhere. Its just the same flapping motion of the wing in still fluid. As for the boundary conditions, use u = 0 for inlet and the same outlet B.C you have mentioned. Dominic |
I currently used symmetry BC, although I believe convective outlet should work fine too.
other B.C you used seem correct except outlet. why you use symmetry BC for outlet? |
