Navier-Stokes spherical discretization
Old   April 14, 2010, 16:52
Unhappy Navier-Stokes spherical discretization
lost.identity is on a distinguished road
I'm trying to discretize the Navier-Stokes equation written in the spherical form for a Finite Volume formulation. I'm having problems due to the 1/r^2 terms appearing in the equation.
I'm following the method of Patankar "Numerical heat transfer and fluid flow" where he integrates the equation for the control volume.
It is spherically symmetric so I'm only retaining the radial terms in my equations. Does anyone know how to do this?
Thanks.
lost.identity is offline   Reply With Quote
Old   April 14, 2010, 22:56
ztdep's Avatar
p ding
ztdep is on a distinguished road
Send a message via Yahoo to ztdep Send a message via Skype™ to ztdep
use the control volume center coordiante to compute the 1/r^2.
ztdep is offline   Reply With Quote
Old   April 15, 2010, 05:01
My problem is actually with integrating the equation.
I'm using Favre averaged version of the equation so I have the following convection term
(1/r^2)*d/dr(r^2*rho*u*u)
because u (the velocity) are functions of r I need to integrate this by parts. I tried multiplying the whole equation by r^2, but then this causes the same problem to other terms that doesn't have the (1/r^2) term.
I've tried searching through the literature to find any papers that does finite volume method on spherical Navier-Stokes equation and haven't been able to find any that have done the same thing as what I'm trying to do.
Old   April 15, 2010, 06:16
ztdep's Avatar
p ding
multiply r2 at both sides
Old   April 15, 2010, 07:48
Thanks for the reply.
As I've already mentioned in my email, I've already tried that method. But the problem is when I multiply by r^2 on both sides I get terms like r^2*dp/dr, which again has to be integrated by parts.
But since p is generally a function of r this causes problems in the integration.
In addition I have more complex terms that arises due to Favre averaging such as r^2 d/dr(<rho*u''*u''>), where <> refers to Favre averages. I use the Boussinesq approximation to model this but still I get terms such as r*u, which again needs to be integrated by parts.
Surely, there's another way to do this?
Old   April 15, 2010, 18:59
ztdep's Avatar
p ding
nope do not integrate by part. take r^2 is a constant
Old   April 16, 2010, 05:19
r^2 is not a constant, it arises by writing the Navier-Stokes equation in spherical form. r is one of the variable dimensions.
So when I'm integrating with respect to r, r^2 can't remain a constant.
Old   April 16, 2010, 08:57
agd
agd is on a distinguished road
I'm not sure I'm following what you are actually trying to do at this point. It sounds as if you are trying to integrate the full Navier-Stokes equations analytically. If you want to do a finite volume discretization, then the 1/r**2 term will be a part of what you discretize - in that case you will use the value at the cell center, as ztdep has suggested. Treat it just like any other term in the discretized equation.
agd is offline   Reply With Quote
Old   April 16, 2010, 10:41
Sorry I should've explained it a bit more clearly
So I have the following 1-D Navier-Stokes equation written in spherical coordinates
\frac{\partial\overline\rho{\tilde{u}}}{\partial{t}}+ \frac{1}{r^2}\frac{\partial}{\partial{r}}\left( r^2\overline{\rho}{\tilde{u}\tilde{u}}\right)= -\frac{\partial\overline{p}}{\partial{r}} - \frac{\partial}{\partial{r}}(\overline{\rho{u''}{u''}}) + \frac{1}{r^2}\frac{\partial}{\partial{r}}\left( r^2\overline{\tau_{rr}} \right)
where
\overline{\tau_{rr}} = {2\mu\frac{\partial{\tilde{u}}}{\partial{r}} -\frac{2}{3}\mu \frac{1}{r^2}\frac{\partial{r^2\tilde{u}}}{\partial{r}}}
\overline{\rho{u''}{u''}} = - {2\mu_t\frac{\partial{\tilde{u}}}{\partial{r}} +\frac{2}{3}\mu_t \frac{1}{r^2}\frac{\partial{r^2\tilde{u}}}{\partial{r}}} + \frac{2}{3}\overline{\rho}\tilde{k}
Now what I want to do is integrate this momentum equation over the control volume and over time. Since it's 1-D I only consider a control volume around a single grid point P, the grid point East of point P is referred to as E and to the West is referred to as W.
Let's say I want to integrate the term
\int_t^{t+\Delta{t}}\,\int_P^E\, \frac{1}{r^2}\frac{\partial}{\partial{r}}\left( r^2\overline{\rho}{\tilde{u}\tilde{u}}\right) \, dr \, dt
If the 1/r^2 term wasn't there this would have been straightforward, which is the case in the Cartesian coordinates.
So one thing I tried to do was to multiply the whole equation by r^2. But then I get terms like
\int_t^{t+\Delta{t}}\,\int_P^E\,r^2\frac{\partial}{\partial{r}}(\overline{\rho{u''}{u''}}) \,dr\,dt
which again gives me the same problem. This may be different to what's normally done in Control Volume analysis.
I'm trying to use the method of Patankar "Numerical Heat Transfer and Fluid Flow", 1980.
Thanks.
Old   April 16, 2010, 12:07
ztdep's Avatar
p ding
r^2 tem represent the element volume in the sperical coordinate system Dv. as in cartesian coordinate, it is 1 dx dy dz.
Old   April 16, 2010, 13:41
Thanks, I think I sort of know what you're saying.
Are you saying that when I multiply by r^2, and integrate then terms such as
\int_P^E\,r^2\frac{\partial}{\partial{r}}(\overline{\rho{u''}{u''}}) \,dr= \Delta{V}\left [ (\overline{\rho{u''}{u''}})_E-(\overline{\rho{u''}{u''}})_P \right ]
is this true for 1-D case such as mine? and would \Delta{V}=1?
or is \Delta{V} = r_P^2\Delta{r}
where r_P^2 is the radial value at the mid-point of the control volume?
Old   April 16, 2010, 21:36
ztdep's Avatar
p ding
yes, that is what i mean/
by the way , how do you input the formular?
Old   April 17, 2010, 17:06
THanks
Just want to confirm, you mean
The site uses Latex formatting to type equations. If you click any of the equations you'd see the code.
Old   April 18, 2010, 12:39
Exclamation
  #14
Actually shouldn't it be
\int_P^E\,r^2\frac{\partial}{\partial{r}}(\overline{\rho{u''}{u''}}) \,dr = \Delta{V} \left [\frac {\partial}{\partial{r}}(\overline{\rho{u''}{u''}}) \right ]_e= \Delta{V} \left [ \frac{(\overline{\rho{u''}{u''}})_E-(\overline{\rho{u''}{u''}})_P}{\Delta{r}} \right ]
where \Delta{V} = r_e^2\Delta{r}, P and E refers to the left and right hand side faces control volume respectively, and e is the midpoint of the control volume.
which would finally give
\int_P^E\,r^2\frac{\partial}{\partial{r}}(\overline{\rho{u''}{u''}}) \,dr = r_e^2 \left[ (\overline{\rho{u''}{u''}})_E-(\overline{\rho{u''}{u''}})_P \right ]
Thread Tools
Trackbacks are On
Filtered navier stokes equation..LES:: Palani Velladurai Main CFD Forum 6 September 15, 2011 18:07
Navier Stokes, Pressure BC, Discretization Sree Main CFD Forum 0 August 1, 2007 04:55
Navier stokes compresible viscid flow fea, somebody can help? Jose Choy Main CFD Forum 3 October 24, 2003 02:28
Newbie:Viscoelasticity and Navier stokes equation Rajil Saraswat Main CFD Forum 2 June 9, 2003 07:21
help: I am trying to solve Navier Stokes compressible and viscid flow Jose Choy Main CFD Forum 2 May 18, 2000 05:45
