LES on two phase flow
Old   May 12, 2004, 08:10
Default LES on two phase flow
Li Yang
Hello everyone,
When I use "LES and two phase" to search, I could not find many papers. However, when I use "LES and combustion" to search, I can find hundreds papers. I can see LES on combustion work get published every month.
I am wondering if the turbulent effect is not so important in two phase flow or LES on two phase flow is too complicate ? It doesn't seem very active in this area at the moment.
For attached flow or flow with small separation, RANS simulation is probably accurate enough for engineering application. Only when there are large separations or large re-circulations or flows like jets, LES becomes important as RANS can not simulate them very well. Do you think this is the reason that not many LES work on two phase flow have been done ?
Thanks for your reply in advance.
Li
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) florian_krause OpenFOAM 22 June 13, 2013 21:25
Two phase flow with condensation Sunnie FLUENT 0 May 31, 2009 10:02
Validation for laminar Disperse phase flow shashwat Main CFD Forum 0 April 4, 2008 02:20
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
